Hey guys, I am a new Tuff Book owner and have a question about the battery.
My battery will run completely down in about two weeks with the computer
shut completely off (charger not connected) but if I take it out of the computer it stays charged indefinitely
Is this normal or do I have a problem ?
Thanks Jim
CF 18-Mk5
CF- 18 NDHZDVM
						Battery runs down with computer off
Re: Battery runs down with computer off
That's sounds about right. When I store my Toughbooks I just open the battery door and pull the battery out a little. Problem solved.
That's normal, even the non-toughbook pc's do that.
Thanks guys
I really appreciate the info, Is this a great forum or what
Jim
Jim
You bet
