Wireless router for 3g
My girlfriend has a usb Verizon card. That is her main and only internet right now. She was using her dell to use a program called connectify. It let her use that dell as a wireless router. Since the dell is dead now this program won't work on her other laptops so I did some digging. It needs a newer wifi card in the laptops she was using. I know they make regular routers that you can plug you usb card into and it will automatically broad cast it out. I haven't personally used any. Has anyone here used one? If so what do you recommend?
