touchscreen strikes back....
psych0Thrasher
#1 Post by psych0Thrasher »
I posted this on NBR early I'm sure i'll get a quicker response on here
On one of my cf29Es, I got the touchscreen working but i needed to clean the bezel. Had a bunch of crap in it so i decided to take apart the LCD case to do a more thorough job of cleaning it. hooked it back up and it was working intermittently so I went to wiggle the TS ribbon cable and it just stopped all of a sudden. I think i may have popped a fuse. I searched the forum for Ohlip's thread about the fuses but I keep getting the 404 error and it's starting to tick me off. Anyone know which fuse(s) I need to check and where they are located or at least direct me to the thread that was talking about them.
Dan
Doobi
Re: touchscreen strikes back....
#2 Post by Doobi »
Not if I can't get on NBR. It's been down for me all day.
~Paul ;)
Philippians 4:6-7"
Panasonic CF-29 Toughbook - 1.6Ghz - 100 GB 7200 RPM HD - 1.5GB of RAM - GPS - Internal WiFi - Sierra Wireless EVDO - 13" Touchscreen - DVD/CDRW Drive - Media battery - BT enabled with BT PCMIA mouse - backlit keyboard - :D
Anyone for a game? Look for Doobi!! :p
http://www.letsplaychess.com
#3 Post by Rob »
Damnit... I just had it up - I should have edited Dan's post with the question and just put it here... It's down now like usual...
#4 Post by Rob »
I got it. I edited the first post for him...
Who knows when NBR will be down again :doh: ...
EDIT: 29 minutes later and its down AGAIN...
psych0Thrasher
#5 Post by psych0Thrasher »
Well thanks for the edit. :headbang:
NBR has really been getting on my nerves the last few days. I'm glad i'm not the only one experiencing it though :mad: :doh:
Dan
Doobi
#6 Post by Doobi »
You might be in luck. I think I saved that schematic from Teo where he circled ALL the fuses. Give me a minute..
EDIT: Yay me!!! Found it... ROBWhat the hell dude! PDF attachments are NOT allowed!!!!!
~Paul ;)
Philippians 4:6-7"
Doobi
#7 Post by Doobi »
THATS IT.... IM going BACK to NBR............. *Slams Door on his way out**
3 seconds later....
Uh, ya, there still down. Guess I'll stay here.
~Paul ;)
Philippians 4:6-7"
#8 Post by Rob »
Doobi wrote:You might be in luck. I think I saved that schematic from Teo where he circled ALL the fuses. Give me a minute..
Well then... I just fixed it.
Try now :)
Doobi
#9 Post by Doobi »
NICE!
FUSE.pdf
(462.56 KiB) Downloaded 1294 times
~Paul ;)
Philippians 4:6-7"
psych0Thrasher
#10 Post by psych0Thrasher »
Thanks Doob! :clapping:
I actually found that file on NBR last night too. But I need the fuse diagram for the cf29 :pat:
