Modded CF-18 with GPS
Toughbook
Re: Modded CF-18 with GPS
#11 Post by Toughbook »
What about regular GPS Street Nav that is dual use like XP/Linux... Anything out there?
Silver Trooper
#12 Post by Silver Trooper »
I am doing an OEM GPS install on a CF-18. Does anyone in the forum have the part numbers for the antenna cap and the other parts associated with the install? All I need are the numbers for the parts from the antenna out. Thanks!
#13 Post by teo »
Robert,
here are list that you need: 1.0) GPS antenna cover - DFHR6231ZA-0
2.0) GPS waterproff sheet - DFHR3C68ZA
3.0) GPS antena - EBMGMD51R5VD
4.0) Gasket - DFHE0834YA
5.0) GPS holder - DFHM0394ZA
Hope it helps
Silver Trooper
#14 Post by Silver Trooper »
Teo,
Thanks much!
Robert
#15 Post by teo »
I've done a bet progress on Cf-18 gps by using the patch antena at the top fo Lcd. The result is much better than the pocket where the OEM antena located. I just need some finishing or maybe replacing the cover of the antena. It just happened the antena cover came from the body of my mastercraft tool box, Lol.......Teo
Picture 007111.JPG (41.59 KiB) Viewed 18964 times
psych0Thrasher
#16 Post by psych0Thrasher »
Teo, do u think you could cram a patch antenna into one of those wlan antenna covers from the 29? I don't have any antennas around me right now to try it out but I'll try later tonite and let ya'll know how it goes. I have like 20 of these covers and I would like to find a good use for them
Dan
#17 Post by teo »
The patch antena is to big and when it does. It is easy to break.
