usb ports
Re: usb ports
Not all toughbooks have that.
Re: usb ports
I almost had to on my Cf-29 before I sold it to get my30, but my IT guy sent me almost a whole lower...almost all boards and port covers lol it came in the other day
Re: usb ports
Any one know what thermal pad is for the30's or size or recommendations....it's getting to be summer and I'm opening it up might as well change them
Re: usb ports
read the linked thread....
http://forum.notebookreview.com/panason ... -pads.html
1.5mm is the correct thickness You will need 2 or 3 1/2 square pads depending on what model you have.
Actually the cf29 uses a putty that comes in a sheet form. I opened a parts cf29 and I took the thermal material off and rolled it into a ball.
Fujipoly is what I came up with to use.
Fujipoly
150-XPE
150 means 1.5mm XPE is the material.
The XPE has a thermal conductivity of 11 W/mK. Which from what I found out is really high performance. Thermal conductivity of 6 W/mK is considered high performance.
http://www.FrozenCPU.com
Fujipoly
150-XPE
Re: usb ports
Found this on eBay. Hmm.... http://pages.ebay.com/link/?nav=item.vi ... 1397383652
Re: usb ports
Re: usb ports
See that's what's weird Is one thing on that eBay add says1.5 other says one....
Re: usb ports
well shawn i just ordered the ones you recommended, ill be installing them next weekend when i get back from being out of state. thanks for the advice
Shawn wrote:1mm is too thin...
try this instead....
http://www.frozencpu.com/products/16881 ... 8c487s1289
