Custom TOughbook Badges
j0llyr0ger
Re: Custom TOughbook Badges
#11 Post by j0llyr0ger »
I do have black material that lasers white, also, I can do brushed stainless or aluminum look on top of that.
THe zombie is a combo of that.
#12 Post by SHEEPMAN! »
I need a CF-30 label with Bellsprings Fire on it....can do?
Like this I hope:
BELLSPRINGS
FIRE
Font for FIRE could be a tad larger.
This may turn into three...one for CF30MK3 and 2 for CF-19 MK1 and MK3.
mad edit: Fire wants to be centered as the preview showed and the helpful editor changed for me. :blowaway:
#13 Post by toughasnails »
Here is my custom badge guys.. :cheers:
mklym
#14 Post by mklym »
Nice!
#15 Post by SHEEPMAN! »
All right how about this. This is a crop from a small jpg...I can do better maybe via email.
j0llyr0ger
#16 Post by j0llyr0ger »
I can make one based on that Image, I'll have to redraw it, but no big deal.
Let me know if you want one.
Also someone wanted a bunch of replacement ones, I found some good material that matches (although thicker than original) and here's a test piece. Let me know.
mklym
#17 Post by mklym »
j0llyr0ger wrote:Also someone wanted a bunch of replacement ones, I found some good material that matches (although thicker than original) and here's a test piece. Let me know.
That would be me. :) That looks good. When you say the material you used to make the badge in the photo is thicker than original, do you mean thicker than a factory badge or thicker than the material you used to make Blair's badge? Thanks.
#18 Post by teo »
j0llyr0ger wrote:I can make one based on that Image, I'll have to redraw it, but no big deal.
Nice! Can you ad additional black trim along side of the dog bone shape. Let say 5mm. If you've done. let us see and I will order 10pcs.
j0llyr0ger
#19 Post by j0llyr0ger »
Same thickness as Blair's, but thicker than the OEM. However, someone alerted me to copyright issues, and I honestly never even thought of that. Not like I'm "really" competing with Panasonic, but you know how much BS is involved with copyright law. So I guess I can't make branded ones.
#20 Post by teo »
Ad a trim that I have requested along side and it is no longer an issue.
