CF-29L (MK-4) WWAN HELP... SB555 for VZW
copracer1990
#1 Post by copracer1990 »
I am looking for any help installing the SB555 sled on my CF-29L or MK-4 unit. It had one before I got it. The person I got the 29 from pulled the WWAN sled for use in another 29. I have a sled with the SB555 module in it, and there are DIP switches on the sled. Any help with drivers and DIP settings would be great. I have the WWAN turned ON in BIOS and the COM port set to AUTO, the power light and power button work, never shows up in windows device manager. Tried the drivers/software for Verizon, Watcher 6.4.2 and no go!!! I am stumped, please help!!
If it isn't broken, take it apart to see why it is working!!
(1) CF30CCS80BM~TOUCHSCREEN~1.6GhzCORE 2~80g HD~4G RAM~EMISSIVE BACKLIT~INTEL 4965ABGN~GOBI~WINDOWS 7 ENTERPRISE~
(1) CF29LWQGCBM~TOUCHSCREEN~1.6Ghz~1.5G RAM~RUBBER BACKLIT~INTEL2915ABG~80g HD~WINDOWS 7 ENTERPRISE~
(1) CF27LBAGHEM~TOUCHSCREEN~500Mhz~512MB RAM~DUAL BOOT XP & WIN98SE~60g HD~ EMISSIVE BACKLIT~GREAT FOR PROGRAMMING MY 2 WAY RADIOS~
(1) CF-M34~TOUCHSCREEN~unknown specs for running OBDII scanner~
tomcat57
Re: CF-29L (MK-4) WWAN HELP... SB555 for VZW
#2 Post by tomcat57 »
Did you download old watcher drivers ?
Does your cell phone data provider even support or allow this old modem on their network
Technology especialy cell phone networks changes quickly ,this is quite old
