HERE WE ARE! Clay helped me out with this too so I give him 50% of the credit! THANKS CLAY! about $41 in materials + 4 hours of time. Also, I currently have a 5" nipple attached to the flange and I'm going to be removing that and putting a 7" nipple on it because it's rubbing against my center "kitchen table" in my truck which is no good. Also in the pics it shows the CF-29 behind the seat - well it bounces around and makes noise back there so I ended up putting it under the seat and it's just perfect that way. I just use a flash drive to put music on it so I don't have to take it outta my truck.
Enjoy!
Holy Crap! My mount actually worked
Re: Holy Crap! My mount actually worked
So after 9 months I am finally complete again, I have my Toughbook back.
I never got around to posting pictures of the redone mount, so herer they are:
- Lefthand View 2.jpg (31.98 KiB) Viewed 7002 times
- Bottom View 3.JPG (106.99 KiB) Viewed 7002 times
- Bottom View 4.JPG (110.83 KiB) Viewed 7002 times
- Bottom View 2.jpg (96.85 KiB) Viewed 7002 times
CF-18FHAZBBM 1.1GHz/1.25GB RAM/160GB HDD (CAR MOUNTED)
CF-30CAQAZBM 1.66GHz/1GB RAM/80GB HDD
Clay! Good to see you! When will you come by the office to visit?
w00t!
P.S, when will you buy a CF-31? Haha!
w00t!
I'm coming homw for deployment block leave on October 28, I'll be stopping in between then and November 14. As for the CF-31, maybe after deployment.
