CF-29 Blue Tab VS Yellow Tab batteries for CF-29
#1 Post by Rob »
If one were to choose which should I choose?
Yellow Tab CF-VZSU29A - 18 cycles - 7.65Ah
Blue Tab CF-VZSU29 - 33 cycles - 6.6Ah
If I recall correctly the blue tab batteries are better right??? If that is the case then why are the yellow tab batteries higher capacity (7.65 vs 6.6)??
tomcat57
Re: CF-29 Blue Tab VS Yellow Tab batteries for CF-29
#2 Post by tomcat57 »
The cycles are very low on both , close to new
The yellow Tab is newer and higher capacity...Go for the yellow tab
#3 Post by Rob »
Alex, is this the same with the CF-18's?
tomcat57
#4 Post by tomcat57 »
Yes
The cf-18 blue tabbed battery is original lowest capacity , and first in the series ,
so the other batterys are higher capacity and fresher
#5 Post by Rob »
Okay... and.... my CF-30 has a blue tab battery in it too... Are there Yellow tab batteries available yet for teh 30's?
#6 Post by toughasnails »
Rob , I have only seen the blue tab for the 30. I did a search before I bought my spare battery but only found the blue tab.
