CF-52 disassembly manual
dan95gst
#1 Post by dan95gst »
Hi everyone, new to the forum.
Ive got a few (read 20) toughbooks i have to get prepped for deployment at my job. However a previous systems admin decided they need bios passwords and decided NOT to make a note of that in his password document that he made for us when he left 6 months ago.
Ive found online that i need to reset a jumper on the bios next to the battery, however i cant get the damned thing apart. i know its just 1-2 screws holding me up, but with 20 of these to do, i need some serious help.
If you can provide a service manual for me i would greatly appreciate it.
-Dan
Re: CF-52 disassembly manual
#2 Post by Rob »
Please provide the FULL model number.
dan95gst
#3 Post by dan95gst »
cf-52ggnbx2m
#4 Post by Rob »
I don't have that exact one but I have one that is close... it should work.
CF_52CCABVBM.pdf
(1.61 MiB) Downloaded 1015 times
dan95gst
#5 Post by dan95gst »
appreciate the manual.
helped me get it apart. however pulling the battery off the bios for a half hour didnt clear the password.
anyone know of like a master password for these things? if that is even available?
#6 Post by toughasnails »
You could try killcmos http://www.download3k.com/Install-KILLCMOS.html
or this one http://www.cgsecurity.org/wiki/CmosPwd
you might also want to read Teo's thread (CF-30) where he had a password in his bios and check the things he tried http://www.toughbooktalk.com/viewtopic.php?f=2&t=393
Good Luck
#7 Post by Rob »
This has been discussed many times before with no luck I don't think... I've personally never had luck on CF-18's, 19's or 29's...
