So I've never been able to connect to either of my SANS over the network. I started researching and I found this from one of the websites I found. You should add this registry value if you are having problems where you are logging in with the correct credentials but it still isn't working:
Once you have drilled down to HKEY_LOCAL_MACHINES\System\CurrentControlSet\Contr ol\Lsa click on LSA in the folders window (left).
Next click Edit \ New \ DWORD (32 bit) Value \
The new Dword is LmCompatibilityLevel and the value is 1
This solution worked for me.
Windows 7 can't connect to some network drives SOLUTION!
Re: Windows 7 can't connect to some network drives SOLUTION!
Rob,
Have you tried adding the Netbeui protocol that is a part of the XP protocol as well.
Bill
CF-29 M Touch
CF-30 Mk1 Touch
CF-19 Mk3 Touch
Bill
CF-29 M Touch
CF-30 Mk1 Touch
CF-19 Mk3 Touch
