It is currently Fri Feb 15, 2019 3:35 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Tue Feb 09, 2010 7:31 pm
Sure
The third connector which is to power the keyboard requires 5vdc for full brightness
Its led so if you hook have the polarity backwards it won't light up, but no harm is done
Alex
PostPosted: Tue Feb 09, 2010 9:29 pm
tomcat57 wrote:
The rubber backlite two cable will probably not light up
I tried on a cf-72 and is did not,so I am thinking the same on the cf-73
If you can find a source of 5vdc,like usb power you can try a 3 cable and mod it
Its my plan on the cf-74
Alex
Do the 72, 73, and 74 take the same keyboard? Cuz I know a 72 keyboard (non-backlit) will fit perfectly into a 28.
The 28 will light up a 2-cable rubber backlit, same as a 27, but apparently the 72 will not. There were kits with the little Texas board for the 28 that fired up two different 3-cable backlit keyboards: the green high-voltage emissive and also a more rare circuit that fires up the 29 type chicklet emissive. I would bet either of those could be modded into a 73 if the keyboards will physically fit and the other 2 cables will fit.
PostPosted: Wed Feb 10, 2010 12:53 am
The keys might be too high
Alex
PostPosted: Wed Feb 10, 2010 7:41 am
I tried the 28 keyboard in both a 72 and a 74. Neither would light up. Also, they did not fit quite right as the tabs along the front did not align and trying to screw down the keyboard retainer was a problem.
PostPosted: Wed Feb 17, 2010 2:04 am
Yea, I had a question about installing a Back-lit Keyboard on a CF-73 as well. I have seen them installed on CF-72's and the Back-light function works, but I haven't seen them installed in a CF-73 before. They DO make Rubber Back-lit keyboard's that have 2-Ribbon cables and I know this for sure as a few have gone through my hands..
So are we any closer to answering the ultimate question? "Will it work on the CF-73?" 8)
PostPosted: Sat Apr 17, 2010 1:37 am
No. There isn't a lit keyboard for neither the CF-73 nor CF-74.
Users browsing this forum: No registered users and 0 guests
