I just got an FZ-55 Mk1, I purchased a GPS board on Ebay which is showing 19-20 satelites using the Panasonic PC GPS viewer app.
I struggle to find information/help on how to use this with a map app. I want to also have offline maps available.
Does anyone have advice here?
Thanks - Mark
						Using Built in GPS
Re: Using Built in GPS
You can do whatever you like! All you need is the right software and then just tell it what port your GPS is on (or let it scan) and then go from there.
What specifically were you needing?
