Windows 10 certified CF-31?
SJLPHI
#1 Post by SJLPHI »
Hello,
I've had a CF-19 for a while and I really liked it but since I upgraded my Mk 6 from Windows 7 to Windows 10, every few update made the computer unstable. I don't know what the reason was at the end but I gave up and decided to get myself a Mk 8 and so far no crash and I am quite happy.
Now, I've been wanting to get a CF-31 for a long time and with my underclock "addiction" I want Mk 5. I remember reading that within CF-19 branches, Mk 8 is the only one that has Windows 10 certification. Is there such certification for CF-31? I would guess since 5th gen on Mk5 came out after Windows 10 came out, it must be certified for W10, no? I am reading at this forums that a lot of people are having stability issues with W10 so I am a bit hesitant on spending the money.
Rich
Re: Windows 10 certified CF-31?
#2 Post by Rich »
CF-31 Mk4 and up, there are one click driver bundles for Windows 10 on the Panasonic site.
We get some rules to follow.
CF-20 Mk1, CF-31 Mk5 i7, CF-31 Mk6 i7, FZ-G1 Mk2, CF-54 Mk2, CF-33, FZ-Q2, CF-74J,
Azrial
#3 Post by Azrial »
Damn, Mk 4 and up huh? I guess that leaves my trusty CF-31AAAAX1M in the dust and stuck at Win7! :pat:
Rich
#4 Post by Rich »
We have a Mk1 at work that I put 10 on. Worked fine for a while, then got slow, then WiFi would intermittently stop working. I tried using a usb WiFi dongle, same result. I wiped the ssd and reinstalled 7 pro, internal WiFi works perfectly again and speed came back to normal. It must not have liked 10 very much. I think it’s the same model as yours.
#5 Post by Rob »
Yes MK2 will run it but you have to get creative with the drivers. Need at a minimum 8GB RAM and a 256GB SSD. Ideally for modern worlds you'd want 16GB RAM and 512GB SSD. We prefer Samsung SSD's.
