CF-30 RAM upgrade
Re: CF-30 RAM upgrade
#11 Post by ADOR »
The above threads deal with a NBR member putting 8 GB of DDR 2 ram into his CF-30 Mk2 directly.
If one of the 4gb chips you have works by it's self, it may not match well with the 2 gb sticks to work. If you can get one of those 4gb sticks to work and have any other old ram laying around or can borrow from another pc you can try that to see if you can get it to work.
n4wwl
#12 Post by n4wwl »
Well, I don't have extra RAM sticks laying around, but if I get brave I might try it again using each 4gb stick separately to see if they each will work independently.
#13 Post by ADOR »
That would be my first plan of attack as well. But mentioned the ram incase you had a old 512mb or 1gb ram laying around like some of us do.
Azrial
#14 Post by Azrial »
ADOR wrote:Here is the offical thread from the 8gb of ram upgrade on a mark 2. He used the low density. Think most toughbook ram is low density double row.
http://forum.notebookreview.com/threads ... ry.752813/
Discussion about ram before it was installed
http://forum.notebookreview.com/threads ... k2.751942/
As of yesterday, that PC is still working, for the current owner. :D
