Max RAM memory on a CF-31 Mk3
Mainumbí
#1 Post by Mainumbí »
Hi, everyone.
I have a CF-31SBLAB1M. Reading about the hardware of this model I came across this page: https://ark.intel.com/content/www/es/es ... 0-ghz.html
Apparently, the Intel i5-3320M can handle up to 32 Gb of RAM. Is it correct? I know this forum has a history of members pushing the memory capacity of the Panny to the limits, (which is amazing, BTW).
Is it doable? Have anyone done this?
Many thanks.
Re: Max RAM memory on a CF-31 Mk3
#2 Post by kode-niner »
With only two SODIMM slots it would be an expensive test.
Mainumbí
#3 Post by Mainumbí »
kode-niner wrote:With only two SODIMM slots it would be an expensive test.
Yes, indeed. But I have the opportunity to buy used modules from a coworker for a fraction of new ones, so I could give it a try. However, I want to know the feasibility of doing so before trying it.
#4 Post by Rob »
Negative... 16GB is all this will handle. I've tried with 32 with no success.
UNCNDL1
#5 Post by UNCNDL1 »
I'd like to add some RAM to this MK 4 31 unit.
What's a good link to view specs and pricing?
Mainumbí
#6 Post by Mainumbí »
Rob wrote:Negative... 16GB is all this will handle. I've tried with 32 with no success.
Many thanks, I knew somebody, somewhere, might try this before. You spare me a substantial amount of money.
