Linux Mint 18.3 on CF-19 wi-fi connecting issue
Re: Linux Mint 18.3 on CF-19 wi-fi connecting issue
Here's advanced N6235 on CF-31 MK3. I had just blacklisted wl.
- Screenshot-8.png (111.25 KiB) Viewed 7334 times
chris@CF-19 ~ $ dmesg | grep Intel
[ 0.000000] Intel GenuineIntel
[ 0.000000] Reserving Intel graphics memory at 0x00000000ce000000-0x00000000cfffffff
[ 0.036000] smpboot: CPU0: Intel(R) Core(TM) i5 CPU U 540 @ 1.20GHz (family: 0x6, model: 0x25, stepping: 0x5)
[ 0.036000] Performance Events: PEBS fmt1+, Westmere events, 16-deep LBR, Intel PMU driver.
[ 3.240953] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.240955] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.446172] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 3.956118] pci 0000:00:00.0: Intel HD Graphics Chipset
[ 20.029506] Intel(R) Wireless WiFi driver for Linux
[ 20.029509] Copyright(c) 2003- 2015 Intel Corporation
[ 20.374433] input: HDA Intel MID Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 20.374608] input: HDA Intel MID Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 20.490000] iwlwifi 0000:0a:00.0: Detected Intel(R) Centrino(R) Advanced-N 6235 AGN, REV=0xB0
chris@CF-19 ~ $
chris@CF-19 ~ $
chris@CF-19 ~ $ lsmod | grep wl -i
iwldvm 229376 0
mac80211 778240 1 iwldvm
iwlwifi 282624 1 iwldvm
cfg80211 622592 3 iwlwifi,mac80211,iwldvm
chris@CF-19 ~ $
I did find something here that suggests my adapter is supported, maybe I need to run that tar file.
https://wireless.wiki.kernel.org/en/use ... rs/iwlwifi
Once I am connected the connection has not dropped out.
iwldvm 229376 0
chris@CF-19 ~ $
So wl is already missing in action, blacklisted, or not used by Mint. That's good.
Assume kernel is misspelled...trying again.
Yes I recognize this page. I like the way they write. You'll find disturbing information re: my 8260 card in the footnote....
Onward and upward,
A comment I remember was one where the user found running the card with LAN plugged in did something good...details hazy. It was a one shot deal during set-up.
Animals to feed.
Cya
Onward and upward,
Animals to feed.
Cya
Here is another one. I also tried the Intel microcode update but that would not connect at all wirelessly. I also downloaded the tgz file from the wiki link but so far have not been able to get it to install. I see I have a lot to learn about communicating with linux, need to find a source for the commands to use. EDIT Yes kernel was misspelled, link now works.
chris@CF-19 ~ $ inxi -iFxz
System: Host: CF-19 Kernel: 4.15.0-36-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3)
Distro: Linux Mint 18.3 Sylvia
Machine: System: Panasonic product: CF-19VMRFX2M v: 004
Mobo: Panasonic model: CF19S-4 v: 1
Bios: American Megatrends v: V4.20L11 date: 07/20/2010
CPU: Dual core Intel Core i5 U 540 (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 4788
clock speeds: max: 1200 MHz 1: 1017 MHz 2: 1094 MHz 3: 901 MHz
4: 895 MHz
Graphics: Card: Intel Core Processor Integrated Graphics Controller
bus-ID: 00:02.0
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
Resolution: 1024x768@60.00hz
GLX Renderer: Mesa DRI Intel Ironlake Mobile
GLX Version: 2.1 Mesa 18.0.5 Direct Rendering: Yes
Audio: Card Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k4.15.0-36-generic
Network: Card-1: Intel 82577LM Gigabit Network Connection
driver: e1000e v: 3.2.6-k port: e040 bus-ID: 00:19.0
IF: enp0s25 state: down mac: <filter>
Card-2: Intel Centrino Advanced-N 6235
driver: iwlwifi bus-ID: 0a:00.0
IF: wlp10s0 state: up mac: <filter>
WAN IP: <filter> IF: enp0s25 ip-v4: N/A ip-v6: N/A
IF: wlp10s0 ip-v4: <filter> ip-v6: <filter>
Drives: HDD Total Size: 500.1GB (3.3% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABD0 size: 500.1GB
Partition: ID-1: / size: 451G used: 7.8G (2%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 8.51GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 49.0C mobo: 49.0C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 197 Uptime: 16 min Memory: 597.2/7903.3MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481) inxi: 2.2.35
chris@CF-19 ~ $
4: 895 MHz
bus-ID: 00:02.0
chris@CF-19 ~ $
I keep forgetting....auto connect.
This:
This:
- wifi.png (31.07 KiB) Viewed 7323 times
here is output from CF-31 ...more appropriate. Last line is interesting.
For what it's worth: https://www.cyberciti.biz/faq/linux-fin ... r-chipset/
jay@mx17:~
$ modinfo iwldvm
filename: /lib/modules/4.15.0-1-amd64/kernel/drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.ko
license: GPL
author: Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi Link AGN driver for Linux
depends: mac80211,iwlwifi,cfg80211
retpoline: Y
intree: Y
vermagic: 4.15.0-1-amd64 SMP mod_unload modversions
parm: force_cam:force continuously aware mode (no power saving at all) (bool)
O.K. different machine....just did 246 updates...wl came back or was there all the time.
I blacklisted wl using MXtools and wireless auto started. Interesting....yesterday wireless worked fine.
There's a glitch in the updates.
System: Host: m17aa Kernel: 4.14.0-3-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-17.1_x64 Horizon December 15 2017
Machine: Type: Laptop System: Panasonic product: CF-53AAGZX1M v: 001 serial: <root required>
Mobo: Panasonic model: CF53-1 v: 1 serial: <root required> BIOS: American Megatrends
v: 1.00L14 date: 07/12/2011
Battery: ID-1: BAT1 charge: 55.3 Wh condition: 55.3/84.9 Wh (65%)
CPU: Topology: Dual Core model: Intel Core i5-2520M bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 798 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 851 2: 802 3: 807 4: 841
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915
v: kernel
Display: x11 server: X.Org 1.19.2 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~58Hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 13.0.6
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio
Sound Server: ALSA v: k4.14.0-3-amd64
Network: Device-1: Intel 82579LM Gigabit Network driver: e1000e
IF: eth0 state: down mac: 70:58:12:e3:37:5f
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
IF: wlan0 state: up mac: 8c:70:5a:8b:49:50
Drives: Local Storage: total: 305.51 GiB used: 8.97 GiB (2.9%)
ID-1: /dev/mmcblk0 model: SD8GB size: 7.42 GiB
ID-2: /dev/sda vendor: Seagate model: ST9320320AS size: 298.09 GiB
Partition: ID-1: / size: 290.41 GiB used: 8.97 GiB (3.1%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 44.7 C mobo: 44.7 C
Fan Speeds (RPM): N/A
Repos: Active apt repos in: /etc/apt/sources.list.d/antix.list
1: deb http://iso.mxrepo.com/antix/stretch stretch main
Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
1: deb http://ftp.us.debian.org/debian/ stretch-updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/debian.list
1: deb http://ftp.us.debian.org/debian/ stretch main contrib non-free
2: deb http://security.debian.org/ stretch/updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
1: deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
Active apt repos in: /etc/apt/sources.list.d/mx.list
1: deb http://iso.mxrepo.com/mx/repo/ stretch main non-free
No active apt repos in: /etc/apt/sources.list.d/various.list
Info: Processes: 206 Uptime: 10m Memory: 3.74 GiB used: 549.2 MiB (14.3%) Shell: init
inxi: 3.0.25
L2 cache: 3072 KiB
v: kernel
inxi: 3.0.25
Yeah, Thank you. I followed that direction allready as well. However, a bit of progress! now when I cycle the wireless switch and turn on the wireless settings (2) the connection is made.
All my other device's see the renamed wireless password, whereas LM 18.3 see's the orignal password. Once the original is used LM says ok.
It seems that the CF-19 and LM forget each other and have to get reaquainted again after rebooting. I'm afraid it is what it is for now, but I'll keep looking.
Since iwlwifi is being used how about rolling back to an earlier version of it? What is happening is the same thing I get with wl installed.
Could also be in Network Manager....although the main card it doesn't like is a replacement 8260 Global replacement card. (Not original Panasonic card)
Did we do
I run the same three letter password for install, user and root. (Except for a OS the other day that insisted on 8 letters.) I want to do it my way so that OS is out the window.
Ya know I might have Mint 18.3 downloaded here somewhere. 32 bit or 64 bit?
Did we do
lsmod | grep -i iwlwifi
