It is currently Tue Mar 19, 2019 12:30 am
PostPosted: Fri Sep 21, 2018 6:40 pm
Good evening all,
I am in the process of installing an internal USB headphone amp, and I am wondering what my options are for internal USB connectivity?
  • I am looking for USB in the lower right portion ideally.
  • My CF-31 Mk4 is equipped with 4G card and GPS. No webcam or finger print reader (yet).
  • I presume I could use the header for the finger print reader if I do not want to install this later?
  • I presume I could also pull a wire up to the screen and use the unused header for the webcam? (Inconvenient)
  • Any other options?
--T
PostPosted: Thu Oct 11, 2018 6:48 am
Bumpetibump.
--T
PostPosted: Mon Oct 15, 2018 10:03 pm
I sent you a PM.
PostPosted: Mon Oct 22, 2018 1:50 pm
You could use the WWAN slot as a USB connector with a mPCIe > USB adapter, that's how I used to do Bluetooth on my own 31.
