Cf-19 mk 5
Re: Cf-19 mk 5
#11 Post by toughasnails »
toughkit
sakkara
Re: Cf-19 mk 5
#12 Post by sakkara »
And that is ?
Re: Cf-19 mk 5
#13 Post by Shawn »
the password unless someone changed it from the factory one
User32
Re: Cf-19 mk 5
#14 Post by User32 »
sakkara wrote:Grrrr stelth mode requires a supervisor password
I don't suppose anyone knows the default one or a work around ??
Wut? Concealed Mode normally doesn't need the Supervisor Password, that is unless your BIOS is passworded, then you're SOL as those are pretty much impossible to crack.
What does need a password though is the Optional Kit Configuration and it's password is "toughkit"
Re: Cf-19 mk 5
#15 Post by toughasnails »
When it ask you for a Supervisor Password does it show a spot to put in in ? If not you need to make one. There should be a place to set one.
sakkara
Re: Cf-19 mk 5
#16 Post by sakkara »
All sorted
Thanks for the help everyone
And
Merry Christmas :newbie:
