ME Update Error 8719
- Karl Klammer
This is not Linux specified, but I assume this forum is best suited for reaching out to the relevant crowd ;-)
So, I was delighted to hear that me_cleaner now supports setting the HAP bit:
https://github.com/corna/me_cleaner/com ... 8e377653b7
And thus I wanted to update (and more importantly: backup) my ME firmware prior to cleaning it.
http://pc-dl.panasonic.co.jp/itn/info/o ... 70512.html
Currently running (according to BIOS) :
BIOS V06.00L10 with Config 0011-0000-0007
ME 8.0.10.1464
Hours 11200
on this system: http://www.toughbooktalk.com/viewtopic.php?f=3&t=3176
So, here is the thing. RightClick runas firmware updater batch file states:
Error 8719 Firmware update cannot be initiated because Local Firmware Update is disabled.
Naturally, I formed an educated guess , accompanied by 3 questions, each a refinement of the previous one:
q1) Is that common?
q2) Is this something I should rejoice about ... or did THEY put that disable bit there to prevent backdoor removal?
q3) haeh?
I've got TPM attestation enabled for AEM ... not sure why I say that, maybe hoping for causation? at least correlation?
ME 8.0.10.1464
Hours 11200
q1) Is that common?
q3) haeh?
- Karl Klammer
Re: ME Update Error 8719
ah, coreboot/util/intelmetool solves the riddle.
[user@dom0 intelmetool]$ sudo ./intelmetool -s
Bad news, you have a 'QM77 Express Chipset LPC Controller' so you have ME hardware on board and you can't control or disable it, continuing...
You might be able to run me_cleaner though, idk.Karl Klammer wrote:ah, coreboot/util/intelmetool solves the riddle.
- Karl Klammer
I've booted with grub option iomem=relaxed, which made intelmetool output a bit more verbose:
Bad news, you have a `QM77 Express Chipset LPC Controller` so you have ME hardware on board and you can't control or disable it, continuing...
MEI not hidden on PCI, checking if visible
MEI found: [8086:1e3a] 7 Series/C216 Chipset Family MEI Controller #1
ME Status : 0x1e000245
ME Status 2 : 0x60000106
ME: FW Partition Table : OK
ME: Bringup Loader Failure : NO
ME: Firmware Init Complete : YES
ME: Manufacturing Mode : NO
ME: Boot Options Present : NO
ME: Update In Progress : NO
ME: Current Working State : Normal
ME: Current Operation State : M0 with UMA
ME: Current Operation Mode : Normal
ME: Error Code : No Error
ME: Progress Phase : Host Communication
ME: Power Management Event : Clean Moff->Mx wake
ME: Progress Phase State : Host communication established
ME: Extend SHA-256: (anonymized)
ME: Firmware Version 8.0.1464.10 (code) 8.0.1464.10 (recovery) 8.0.1464.10 (fitc)
ME Capability: Full Network manageability : ON
ME Capability: Regular Network manageability : OFF
ME Capability: Manageability : ON
ME Capability: Small business technology : OFF
ME Capability: Level III manageability : OFF
ME Capability: IntelR Anti-Theft (AT) : ON
ME Capability: IntelR Capability Licensing Service (CLS) : ON
ME Capability: IntelR Power Sharing Technology (MPC) : ON
ME Capability: ICC Over Clocking : ON
ME Capability: Protected Audio Video Path (PAVP) : ON
ME Capability: IPV6 : ON
ME Capability: KVM Remote Control (KVM) : ON
ME Capability: Outbreak Containment Heuristic (OCH) : OFF
ME Capability: Virtual LAN (VLAN) : ON
ME Capability: TLS : ON
ME Capability: Wireless LAN (WLAN) : ON
Let's see how deep the rabbit hole goes.
Having all those underscored "featured" enabled, is a huge motivator for fixing and/or bricking this unit ;-)
- Karl Klammer
yeah, me_cleaner.py works fine, as it just modifies the bin fileUser32 wrote:You might be able to run me_cleaner though, idk.
it's ifdtool that doesn't work, as it flashed the bin file to some eprom
thinkpad x230 also uses qm77 ... people seem to have to use external flashers (e.g. raspi)
currently trying to grok this thingy http://www.corus.pro/pilotes/VAD/VAD517 ... 8%20PV.pdf
also trying to follow a sidequest; figuring out what the heck "outbreak containment heuristic" is supposed to do
- Karl Klammer
okay, after updating bios from V06.00L10 to V06.00L12 and resetting bios-amt config ("unconfiguring ME"),
I get the same results with intelmetool -s, but I also get a different / new error via panasonic me update tool on patched ME.bin
C:\UpdateMeFirmware>UpdateMeFirmware.bat
Panasonic ME Firmware Update Utility V1.00L10
This program updates ME Firmware.
The computer restarts automatically after update.
Do you want to continue? (Y/N) : y
Intel (R) Firmware Update Utility Version: 8.1.40.1456
Copyright (C) 2007 - 2013, Intel Corporation. All rights reserved.
Communication Mode: MEI
Checking firmware parameters...
Warning: Do not exit the process or power off the machine before the firmware up
date process ends.
Error 8771: Invalid File
Press any key to continue . . .
so, hmm, maybe my me_cleaned version was flaky. let's try again with original panasonic ME.bin ... yeah, that looks better
C:\UpdateMeFirmware\Data801>FWUpdLcl64.exe -f MEorig.bin -oemid D6B09D64-DA23-49
A9-8888-F663BE603389
date process ends.
Sending the update image to FW for verification: [ COMPLETE ]
FW Update: [ 100% (Stage: 19 of 19) (|)]
FW Update is complete and a reboot will run the new FW.
so, back to stripping me binary ...
note to self, use -ALLOWSV switch on next try, to allow "same version firmware updates"
note to self: neither BIOS update nor ME update count as hardware change for Metered Boot aka my TPM secret could be unsealed ... scary
hmm, 8771 invalid file issue seems to relate to oemid and/or signing ... seeing that a) me_cleaner wipes out certificate authorities und b) a -SAVE ME_dumped.bin is only half the size of ME.bin ... trying to clean and re-flash the ME_dumped.bin now...
date process ends.
date process ends.
This is a mk6 Cf19, correct?
Any BIOS type work on them is shall I say "challenging". Mk3 CF31's are the same way.
Any custom BIOS work other than a standard Panasonic flash seems to require chip removal and a programmer.
Any software attempt has ended in fail for me.
They will work with ME removed completely. A chip replacement will be required to do that though.
Chip replacement is not for the unskilled. It's VERY easy to ruin a motherboard.
- Karl Klammer
whatever me_cleaner or intel FIT do output is invalid according to FWUpdLcl64.exe, probably due to OEM RSA signing
current challenge seems to be to get a so called "full dump" and see if corna version of me_cleaner and it's -s option play along with this OEM RSA stuff
Me.bin by panasonc is just ME/TXT
FWUpdLcl64.exe -SAVE is not recognized by me_cleaner at all ... but ok, it is not recognized by FWUpdLcl64.exe either .. wtf
my google-fu is weak tonight, my duckduckgo-fu even worse
try again tomorrow, good night ;-)
- Karl Klammer
Anyone have a link for BIOS V06.00L10 ?
can only find BIOS V06.00L12 on pannys site...
want to downgrade again to see if some stuff works on the older version
let me see what I have.
I have a couple backups that are passworded. No idea what version they are.
