CF52 i5 with 13" touchscreen?
Re: CF52 i5 with 13" touchscreen?
Chew on it a bit.
- sq.jpg (7.49 KiB) Viewed 7946 times
You starting to raise squirrels?
That's what I figured. Put it all away for a while.
The NON ATI version of a CF 52 may be possible to swap.
The 15.4 WXGA LCD uses 20 pins of a 30 pin LVDS connector.
It appears that the low resolution Cf 52 panel is also 30 pin
What about the CF-31 screen mentioned? Just far as physical pins.
CF30 is 20 pin also.
It looks like a low res CF52 uses 20 pins of a a 30 pin connector.
I might be able to create a custom LCD cable.
Wonder what the ends of an i3 CF52 lcd cable look like? Compared to a CF52GUN?
