And so I installed a 2 outlet high flow central SHOP Vac...
#1 Post by Rob »
For the shop of course!!!!!
A Tube video will come shortly! But I put in a 2" hose system PVC piping central vac for my tech shop
It is currently run by an 18 gallon Pump Shop Vac but will soon be replaced by this CLEAR 14 gallon system - Because CLEAR with NO BAGS for the shop is practical..... I may vent it outside too......: http://www.lowes.com/pd_757597-20097-88 ... +clear#img
The 18 Gal pump vac will be refocused as a combo disaster response vac combo with an external exhaust for a WHOLE HOME central vac with a BASIC filter bag in it!!! (separate from my shop where we suck up screws, straps and other large odd objects lol :D )
I was always obsessed with vacuums as a kid growing up.... Weird childhood obsessions do not go away as you turn into an adult, they just become larger and more practical! :D
Over and out for now!!! :read: :read: :read:
Re: And so I installed a 2 outlet high flow central SHOP Vac
#2 Post by ADOR »
I plan on having a vacuum hooked up on some tube as well but not as big of a system. It's for a diy flow bench project so I can flow my port work on some cylinder heads.
#3 Post by Rob »
4 x 12' tubes ordered + couplers. - 24' per side!!!
Should be in this week. I will take a video and post after that :)
