I want to trade a regular pair of side antenna cover for CF-19MK3. I need a pair with half wing on it. Let me know or maybe to trade other parts. Thanks
WTT a pair of antenna side cover(CF-19MK3 to MK8)
Re: WTT a pair of antenna side cover(CF-19MK3 to MK8)
I have a full set of wings. Let me find them. They might not be half.
EDIT: 2(ea) DFHR9114 FULL PLUS DFHR6106 TOP if you want them. END EDIT
Make sure they are for the correct mk.
There are differences.
I suspect the top is more for a CF-18 but I do see reference to 18/19 in one advertisement.
All I have to check against is two CF-19MK2.
mk2 is different from mk3 and later.
Check your mk3's.....I will hold them up to the light so you can see them better.
