Getting CF-29 MK4 to wake up from suspend state
Re: Getting CF-29 MK4 to wake up from suspend state
#31 Post by kode-niner »
Hey Jeff, maybe you should add acpi_osi=Linux to your kernel boot.
#32 Post by SHEEPMAN! »
Insert it in front of quiet ...........first try. :cringe:
Here we go.
#33 Post by kode-niner »
So Jeff, did you blow up your '29?
#34 Post by SHEEPMAN! »
Nope.
I think it's a problem with the Intel thingy. CF-30 MK1 works perfect with same USB stick.
Got a bit distracted and I'm not sure I put your recommendation in the right place.
Then there was the 74G with the ghost touch-pad.....today's adventure. Mismatched ram....more like one ram stick bad. Cured now. I only accidentally checked the ram. :pat:
O.K. now where did I put the CF-29. Hey kode...should I send you a CF-29 MK5? :) I have one with only 38,000 hours on it. :boing:
EDIT: CF-74G suspends on lid close and wakes up too. END EDIT inxi below
june@june-CF-74GCDADBM ~ $ inxi -F
System:    Host: june-CF-74GCDADBM Kernel: 3.13.0-24-generic i686 (32 bit) Desktop: N/A Distro: Linux Mint 17 Qiana
Machine:   System: Matsushita product: CF-74GCDADBM version: 003
           Mobo: Matsushita model: CF74-3 version: 001 Bios: Phoenix version: V3.00L18 date: 06/05/2008
CPU:       Dual core Intel Core2 Duo CPU T7300 (-MCP-) cache: 4096 KB flags: (lm nx sse sse2 sse3 ssse3 vmx)
           Clock Speeds: 1: 2001.00 MHz 2: 1600.00 MHz
Graphics:  Card: Intel Mobile GM965/GL960 Integrated Graphics Controller (primary)
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1024x768@60.0hz
           GLX Renderer: Mesa DRI Intel 965GM x86/MMX/SSE2 GLX Version: 2.1 Mesa 10.1.0
Audio:     Card: Intel 82801H (ICH8 Family) HD Audio Controller driver: snd_hda_intel Sound: ALSA ver: k3.13.0-24-generic
Network:   Card-1: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network Connection driver: iwl4965
           IF: wlan0 state: up mac:
           Card-2: Marvell 88E8055 PCI-E Gigabit Ethernet Controller driver: sky2
           IF: eth0 state: down mac:
Drives:    HDD Total Size: 80.0GB (6.2% used) 1: id: /dev/sda model: FUJITSU_MHY2080B size: 80.0GB
Partition: ID: / size: 72G used: 4.7G (7%) fs: ext4 ID: swap-1 size: 2.14GB used: 0.00GB (0%) fs: swap
RAID:      No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 241 Uptime: 1:15 Memory: 376.7/2006.8MB Client: Shell inxi: 1.8.4
#35 Post by SHEEPMAN! »
CF-29 inxi -F
Note the 2 G of ram. Courtesy of non-touch.
nd@nd-CF-29NDLGFBM ~ $ inxi -F
System:    Host: nd-CF-29NDLGFBM Kernel: 3.13.0-24-generic i686 (32 bit)
           Desktop: Cinnamon 2.2.16  Distro: Linux Mint 17 Qiana
Machine:   System: Matsushita product: CF-29N3LGZBM v: 005
           Mobo: Matsushita model: CF29-5 v: 001
           Bios: Phoenix K.K. v: V5.00L13 date: 04/21/2006
CPU:       Single core Intel Pentium M (-UP-) cache: 2048 KB
           clocked at 1600 MHz
Graphics:  Card: Intel Mobile 915GM/GMS/910GML Express Graphics Controller
           Display Server: X.Org 1.15.1 drivers: intel (unloaded: fbdev,vesa)
           GLX Renderer: Mesa DRI Intel 915GM x86/MMX/SSE2
           GLX Version: 1.4 Mesa 10.1.0
Audio:     Card Intel 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller
           driver: snd_intel8x0
           Sound: Advanced Linux Sound Architecture v: k3.13.0-24-generic
Network:   Card-1: Intel PRO/Wireless 2915ABG [Calexico2] Network Connection
           driver: ipw2200
           IF: eth15 state: up mac:
           Card-2: Marvell 88E8053 PCI-E Gigabit Ethernet Controller
           driver: sky2
           IF: eth14 state: down mac:
Drives:    HDD Total Size: 160.0GB (5.0% used)
           ID-1: /dev/sda model: SAMSUNG_HM160HC size: 160.0GB
Partition: ID-1: / size: 69G used: 4.6G (8%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 3.23GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors:   System Temperatures: cpu: 33.8C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 128 Uptime: 1 min Memory: 197.7/2006.8MB
           Client: Shell (bash) inxi: 2.1.28
mac addresses deleted :)
#36 Post by kode-niner »
Heh, I have a MK5 but I blew it up while juggling parts. I should remove it from my sig. ;)
By the way, system wakeup disabled by ACPI could be matched by comparing the numbers with lspci. I think it has to do with the particular component's power saving features more than anything else.
EdFromBJCS
#37 Post by EdFromBJCS »
Hey, fellas. I wanted to let you guys know that I made a couple video tutorials on what I've learned so far. Thanks for all your help.
#38 Post by SHEEPMAN! »
:rolleyes: Ya didn't tell 'em where you learned it I trust. :rolleyes:
lspci o.k.
Processing lambs today. I'll check this (lspci) later.
#39 Post by kode-niner »
I sure could eat a couple of lamb chops right now.
#40 Post by Shawn »
Good show on the vids Ed.
