CF-31P and touchpad (Interlink Versapad)SAGA CONTINUES WORKS
Works fine with Windows LiveCD.
I'm hunting up the Linux commands now.....My 31A worked o.k. with Linux, this 31P is a little different.
Re: CF-31P and touchpad
Okay, what is a windows live cd?
Just like a Linux live cd..But it loads windoze..Mine loads win7
Installed and running W7 Pro. This touchpad is definitely different.
Like it performs like a Synaptics pad. (v.s. PS/2)IOW edge scroll works.
None of the Linux,Debian programs see the pad. synclient reports no synaptic devices.
So it's locked out in a .conf file by default.????
I was hoping you would show up.
Just got back from the woods. Now with extra mosquito bites!
I'd start with (sudo or root) just to see what your kernel thinks...
dmesg|grep mouse
ls -l /dev/input/by-path
lsmod|grep psmouse
O.K. I'm back. Need to dig out the USB wireless mousie.
Repeating myself...every Linux or Debian version says the same thing.
j@mak9:~/Desktop$ lsmod |grep psmouse
psmouse 106647 0
j@mak9:~/Desktop$
That was fun...touchscreen only.
j@mak9:~/Desktop$ ls -l /dev/input by-path
ls: cannot access by-path: No such file or directory
/dev/input:
total 0
drwxr-xr-x 2 root root 80 Aug 18 13:40 by-id
drwxr-xr-x 2 root root 140 Aug 18 13:40 by-path
crw-r----- 1 root root 13, 64 Aug 18 13:40 event0
crw-r----- 1 root root 13, 65 Aug 18 13:40 event1
crw-r----- 1 root root 13, 74 Aug 18 13:40 event10
crw-r----- 1 root root 13, 75 Aug 18 13:40 event11
crw-r----- 1 root root 13, 76 Aug 18 13:40 event12
crw-r----- 1 root root 13, 66 Aug 18 13:40 event2
crw-r----- 1 root root 13, 67 Aug 18 13:40 event3
crw-r----- 1 root root 13, 68 Aug 18 13:40 event4
crw-r----- 1 root root 13, 69 Aug 18 13:40 event5
crw-r----- 1 root root 13, 70 Aug 18 13:40 event6
crw-r----- 1 root root 13, 71 Aug 18 13:40 event7
crw-r----- 1 root root 13, 72 Aug 18 13:40 event8
crw-r----- 1 root root 13, 73 Aug 18 13:40 event9
crw-r----- 1 root root 13, 63 Aug 18 13:40 mice
crw-r----- 1 root root 13, 32 Aug 18 13:40 mouse0
crw-r----- 1 root root 13, 33 Aug 18 13:40 mouse1
j@mak9:~/Desktop$
j@mak9:~/Desktop$ dmesg|grep mouse
[ 1.958334] mousedev: PS/2 mouse device common for all mice
[ 2.511209] psmouse serio2: alps: Unknown ALPS touchpad: E7=00 00 64, EC=00 00 64
[ 2.617780] psmouse serio2: Failed to enable mouse on isa0060/serio2
[ 2.678202] psmouse serio2: Failed to enable mouse on isa0060/serio2
j@mak9:~/Desktop$
That's different.
You check it out. ALPS?
My thought was an ACPI issue......
Time to eat yet again.
psmouse 106647 0
j@mak9:~/Desktop$
/dev/input:
total 0
j@mak9:~/Desktop$
j@mak9:~/Desktop$
That's different.
psmouse 106647 0
j@mak9:~/Desktop$
/dev/input:
total 0
j@mak9:~/Desktop$
j@mak9:~/Desktop$
That's different.
psmouse 106647 0
j@mak9:~/Desktop$
/dev/input:
total 0
j@mak9:~/Desktop$
j@mak9:~/Desktop$
That's different.
alps touchpad.....
http://www.alps.com/driver_win7/index_e.html
https://en.wikipedia.org/wiki/Alps_Electric
https://www.google.com/search?num=20&sa ... 80&bih=617
https://www.google.com/search?num=20&sa ... kgod8vYAaw
https://github.com/he1per/psmouse-dkms-alpsv7
From one of Shawn's linkages above, I found this which might work for you since I think you are using Debian Makulu:
http://forums.debian.net/viewtopic.php?f=16&t=95940
Keep us informed
Keep us informed
