Need information on CF1101770
I know it is a 4G LTE card that is for CF-31's, but that is all the info I have got from PanCan and Google is still not my friend. Looking for detailed info on the card and a place to buy the card. Thanks.
Re: Need information on CF1101770
this maybe 31Gobi5000fu
4G LTE CARRIER MC7355 FIELD UPGRADE FOR CF-31
Panasonic 31Gobi5000fu 4G Lte Multi Carrier (Mc7355 Field Upgrade
https://www.google.com/search?num=20&sa ... S4f_dEbegw
possibly 31A4GLTEFU
https://www.google.com/search?num=20&sa ... Kt_MQgNWV8
I think it's the gobi 5000
https://www.google.com/search?num=20&sa ... 7r4BGvt3pc
possibly 31A4GLTEFU
Thanks for the reply and info Shawn. I thought it might be a Gobi 5000. The CF1101770 is a part number from Panasonic Canada for a WWAN card that will work with Canadian carriers. I don't know if the US field upgrade cards will work here.
according to this chart it will work..Sierra Mc7355 is the official name
http://www.netmotionwireless.com/Data/S ... eivers.pdf
Where do you find this stuff??? The Search Ninja stikes again. Now to track one down.
here...
search terms field upgrade cf19, cf 53 or cf31
http://www.ebay.com/sch/i.html?_from=R4 ... e&_sacat=0
best deal i can find..
http://www.ebay.com/itm/Panasonic-53MK4 ... 1c4b514ca9
Thanks Shawn. I'll check them/it out.
