GPS Map software?
GPS Map software?
which do you use? don't know if Panasonic offered one or if you guys use another. Free would best but open to check out others
CF-C2AKFZGLM My newest one
Re: GPS Map software?
off road or on road?
I use Garmin mobile PC.
I guess on road is best, thanks! Did you pay for that or free download?Shawn wrote:off road or on road?
I actually paid for it. It's discontinued, but I found a copy on the bay. It had a valid serial but did not want to activate. Garmin probably shut down the server. So I used an "alternative" method. Toshiba had it on some of their notebooks. There is a downloadable Toshiba version if you seek....
I even paid for the updated maps...
For topographic maps and W7 (XP) look at USAPhotomaps. Saves tiles to your pc. Free. JDMCox. Can be run in .wine on a Linux box, if you know the set-up. Linux doesn't use com ports per se so ya have to fake it out.
FoxtrotGPS for Linux. Uses open source maps.....and will save to your pc.
Streets and trips 2013
I have a older copy of Delorme TOPO 7.0, streets and trips 2010 and 2005, Navagator. navagator is free and cross platform. I downloaded the USA maps free and did some testing around the house on a android tablet and it worked well. Haven't tried the windows version yet.
http://navigatorfree.mapfactor.com/en/
I use my CF-19 as an offroad GPS. I currently have Streets and Trips 2013, Delorme Street version and topo, Garmin mobilepc and nroute, and a few tile based gps programs.
For offroading using topo maps I found using nroute to be the best with topo maps. I'm from Canada so I found the backroad mapbooks maps to be the best, followed by Ibycus free maps, and finally the garmin maps.
For on road I found Streets and Trips to have the best features but I like the look of mobilepc as it looks like a normal incar gps.
Also look into a program called gpsgateway, it allows you to use an gps receiver with multiple programs at once.
Where did you get the Backroad Mapbooks maps? You use them with Nroute? Have you checked out/tried Fugawi for topo?
Have to pay for the Backroad Mapbooks, never found an alternative for them. I have a copy for one Province and the quality of the maps is great.
I have tried Fugawi but it's a bit of a different animal then nroute.
Oh you may have to convert your backroad mapbook maps for nroute to see them.
