anyone have a problem getting on the wifi?
Got something going on that involves networking, firewalls or wireless? Post it here.
Tactmedic
#1 Post by Tactmedic »
Here is my issue-
My CF-30 sees the router but when I try to connect and enter the password I get this error message-
i plug in password in the "Device Ownership Password" but when I get to the 8th digit it pops an error "Checksum Validation failed for the pin entered"
I am using the "Wi-Fi protected setup wizard" i guess its something for the Intel(R) PROSet/Wireless...
Please help
:doh: :doh: :doh:
CF-C2AKFZGLM My newest one :)
Re: anyone have a problem getting on the wifi?
Install the driver only for the Intel card and use windows built in connection manager
Tactmedic
#3 Post by Tactmedic »
Shawn wrote:Install the driver only for the Intel card and use windows built in connection manager
I have another problem-
When I bought the TB it came with an admin account and it doesn't let me update or change anything on the computer... frustrating :doh:
#4 Post by Shawn »
Did you know it had a password before you bought it? If not, return it for a refund and buy a different unit.
If you got it on Ebay and the seller won't respond to your messages..FILE A CLAIM against him...Ebay will deal with it and get you a refund.
Tactmedic
#5 Post by Tactmedic »
Shawn wrote:Did you know it had a password before you bought it? If not, return it for a refund and buy a different unit.
thats the plan. the seller never said it had a PW on it. It is actually in like new condition- In much better condition than the once in my job :wtf:
#6 Post by Shawn »
Good plan, I am sure several different board members can set you up with a nice unit. Ask for what you want in the Buy Sell forum.
#7 Post by kode-niner »
Meh, you should probably disable WPS on your router anyway since it is inherently flawed, and just use a wifi password.
Tactmedic
#8 Post by Tactmedic »
OK so the seller has finally responded and gave me the PW. I know have Admin rights!! BTW the WiFi issue is fixed, and I am using my 30 right now from work :) thanks guys for helping...
Now I have to figure out how to change the PW, and also how to take out the seller's profile stuff (still says her name on the computer)..
#9 Post by Shawn »
Control panel / user accounts / create new user account (admin)/ login to new account and verify all works okey dokey. Back to control panel / user accounts/ delete old user /
Tactmedic
#10 Post by Tactmedic »
Shawn wrote:Control panel / user accounts / create new user account (admin)/ login to new account and verify all works okey dokey. Back to control panel / user accounts/ delete old user /
Roger that, I'm on it. Thanks :notworthy:
Return to “Networking, Firewalls, & Wireless Talk”
