Mint 17 on a CF-18 Mk3 restarts to a black screen
So like the title says I have a real nice shape CF-18F (Mk3) that I installed mint 17 on. I have 1.5GB ram and 80GB HD and everything seems to run great while in the OS. My problem starts when I try to use the 'restart' button on the shut down menu. It will start the shutdown of the OS and then go to a black screen. Power never cycles and just stays on with a black screen. Only way to get out of that is to hold the power button until it shuts off. If instead of using the restart button I go into terminal and type 'sudo reboot' it will restart with no problem going all the way through the whole cycle including bringing up the bios splash screen and then boot the OS again. I've been searching for a solution, and even tried the grub edit to add 'reboot=bios' and all the other switches/options associated with that to no avail. If anyone has dealt with this before please let me know what if any fix there is. I like Mint and how well it runs just would like to have this quirk go away if possible.
Mark
Mark
Re: Mint 17 on a CF-18 Mk3 restarts to a black screen
All updates installed? Sorry standard question.
I've seen a bug elsewhere.
I'll look it up after a while.
Have you looked at /var/log/dmesg.0 # I think this is the log before the shutdown.
J'd
J'd
As far as updates go yes all the updates through level 3 (level 4 and 5 considered not safe?) have loaded by default. I haven't checked /var/log/dmesg.0 # I'll have to take a look in there when I get home tonight, and let you know what it says.
I'm a bit new to using Linux so bear with me if I sound like a noob. I'm just trying to move away from XP without needlessly bogging a TB with Win 7. I've been on NBR/Panasonic as TB28fan since 2008 when I bought my first CF-28, and joined up here just recently. Two CF-28's, three CF-29's and now this CF-18 makes me one of those "can't just buy one" guys, lol.
My 2 cents. Sorry you are having problems. I'm thinking Mint17 might be a little much for the hardware.
Not sure but think 17 is not final release yet, and there are bugs. Mint 13 has support until 2017 and might be a better starting point. I would try the XFCE version found here:
http://www.linuxmint.com/edition.php?id=113
Works great on my MK1 CF-19 and MK5 CF-29 too. Jeff will definately help sort you out with diagnosis.
Best regards, Cleve
Best regards, Cleve
Mint 17 has Intel issue through several Models, though MK2 (CF-30) is fine. CF-19MK2 is also fine.
What's a noob among friends.
So I initially used Ubuntu 10.10 which ran fast, but it was sort of a pain because due to being unsupported everything was a manual process and I'm still getting acclimated to all this. It did however still exhibit this restart issue even in 10.10. Then I tried Ubuntu 14.04 which really ran slow. I then switched to Mint 17 which is a LTS release thru 2019. This runs very quick on this CF-18. The only thing that could make it better is if the front buttons worked and this restart thing is resolved otherwise I really like it.
As far as the dmesg.0 the following is the contents:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.13.0-24-generic (buildd@roseapple) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #46-Ubuntu SMP Thu Apr 10 19:08:14 UTC 2014 (Ubuntu 3.13.0-24.46-generic 3.13.9)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] Disabled fast string operations
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000ce000-0x00000000000cffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000dc000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000005f6effff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005f6f0000-0x000000005f6f9fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000005f6fa000-0x000000005f6fffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000005f700000-0x000000005fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffbfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Matsushita Electric Industrial Co.,Ltd. CF-18FDHZXVM/CF18-3, BIOS V3.00L13 03/17/2005
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x5f6f0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DBFFF uncachable
[ 0.000000] DC000-DFFFF write-back
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 040000000 mask FE0000000 write-back
[ 0.000000] 2 base 05F700000 mask FFFF00000 uncachable
[ 0.000000] 3 base 05F800000 mask FFF800000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 1GB, type WB
[ 0.000000] reg 1, base: 1GB, range: 512MB, type WB
[ 0.000000] reg 2, base: 1527MB, range: 1MB, type UC
[ 0.000000] reg 3, base: 1528MB, range: 8MB, type UC
[ 0.000000] total RAM covered: 1527M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 16M num_reg: 4 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] initial memory mapped: [mem 0x00000000-0x01ffffff]
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x37800000-0x379fffff]
[ 0.000000] [mem 0x37800000-0x379fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x34000000-0x377fffff]
[ 0.000000] [mem 0x34000000-0x377fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x33ffffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x33ffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x37a00000-0x37bfdfff]
[ 0.000000] [mem 0x37a00000-0x37bfdfff] page 4k
[ 0.000000] BRK [0x01b88000, 0x01b88fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x34b4a000-0x3659cfff]
[ 0.000000] ACPI: RSDP 000f7280 000014 (v00 PTLTD )
[ 0.000000] ACPI: RSDT 5f6f3de6 000030 (v01 PTLTD RSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 5f6f9f54 000084 (v02 MATBIO CF18-3 06040000 MAT 00000001)
[ 0.000000] ACPI: DSDT 5f6f418d 005DC7 (v01 MATBIO CF18-3 06040000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 5f6fafc0 000040
[ 0.000000] ACPI: BOOT 5f6f9fd8 000028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] ACPI: SSDT 5f6f3e16 0001A9 (v01 MATBIO CF18-3 06040000 MSFT 0100000E)
[ 0.000000] 634MB HIGHMEM available.
[ 0.000000] 891MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 37bfe000
[ 0.000000] low ram: 0 - 37bfe000
[ 0.000000] BRK [0x01b89000, 0x01b89fff] PGTABLE
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] Normal [mem 0x01000000-0x37bfdfff]
[ 0.000000] HighMem [mem 0x37bfe000-0x5f6effff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[ 0.000000] node 0: [mem 0x00100000-0x5f6effff]
[ 0.000000] On node 0 totalpages: 390798
[ 0.000000] free_area_init_node: node 0, pgdat c1990a80, node_mem_map f700e020
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] Normal zone: 1752 pages used for memmap
[ 0.000000] Normal zone: 224254 pages, LIFO batch:31
[ 0.000000] HighMem zone: 1270 pages used for memmap
[ 0.000000] HighMem zone: 162546 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] smpboot: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] APIC: switched to apic NOOP
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000cdfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000ce000-0x000cffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000d0000-0x000dbfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000dc000-0x000fffff]
[ 0.000000] e820: [mem 0x60000000-0xff7fffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f6ff7000 s36096 r0 d21248 u57344
[ 0.000000] pcpu-alloc: s36096 r0 d21248 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 389014
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-24-generic root=UUID=2f322ba7-4f72-4428-9f8b-cba1817ac6f1 ro reboot=pci quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3127160 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00037bfe:0005f6f0)
[ 0.000000] Memory: 1508176K/1563192K available (6507K kernel code, 641K rwdata, 2752K rodata, 872K init, 924K bss, 55016K reserved, 650184K highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff14000 - 0xfffff000 ( 940 kB)
[ 0.000000] pkmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xf83fe000 - 0xffbfe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf7bfe000 ( 891 MB)
[ 0.000000] .init : 0xc19ae000 - 0xc1a88000 ( 872 kB)
[ 0.000000] .data : 0xc165b0b2 - 0xc19ad4c0 (3401 kB)
[ 0.000000] .text : 0xc1000000 - 0xc165b0b2 (6508 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f6808000 soft=f680a000
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1097.336 MHz processor
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 2194.67 BogoMIPS (lpj=4389344)
[ 0.004014] pid_max: default: 32768 minimum: 301
[ 0.004085] Security Framework initialized
[ 0.004129] AppArmor: AppArmor initialized
[ 0.004133] Yama: becoming mindful.
[ 0.008039] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.008045] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.008660] Initializing cgroup subsys memory
[ 0.008679] Initializing cgroup subsys devices
[ 0.008685] Initializing cgroup subsys freezer
[ 0.008692] Initializing cgroup subsys blkio
[ 0.008698] Initializing cgroup subsys perf_event
[ 0.008705] Initializing cgroup subsys hugetlb
[ 0.008762] Disabled fast string operations
[ 0.008777] mce: CPU supports 5 MCE banks
[ 0.008817] Last level iTLB entries: 4KB 128, 2MB 0, 4MB 2
[ 0.008817] Last level dTLB entries: 4KB 128, 2MB 0, 4MB 8
[ 0.008817] tlb_flushall_shift: 6
[ 0.029024] Freeing SMP alternatives memory: 32K (c1a88000 - c1a90000)
[ 0.032092] ACPI: Core revision 20131115
[ 0.039144] ACPI: All ACPI Tables successfully acquired
[ 0.040015] ftrace: allocating 27695 entries in 55 pages
[ 0.060205] smpboot: weird, boot CPU (#0) not listed by the BIOS
[ 0.060214] smpboot: SMP motherboard not detected
[ 0.060218] smpboot: Local APIC not detected. Using dummy APIC emulation.
[ 0.060221] smpboot: SMP disabled
[ 0.067787] Performance Events:
[ 0.067795] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.067798] no hardware sampling interrupt available.
[ 0.067803] p6 PMU driver.
[ 0.067808] ... version: 0
[ 0.067811] ... bit width: 32
[ 0.067814] ... generic registers: 2
[ 0.067817] ... value mask: 00000000ffffffff
[ 0.067821] ... max period: 000000007fffffff
[ 0.067824] ... fixed-purpose events: 0
[ 0.067827] ... event mask: 0000000000000003
[ 0.071891] x86: Booted up 1 node, 1 CPUs
[ 0.071898] smpboot: Total of 1 processors activated (2194.67 BogoMIPS)
[ 0.072039] NMI watchdog: disabled (cpu0): not supported (no LAPIC?)
[ 0.072255] devtmpfs: initialized
[ 0.072760] EVM: security.selinux
[ 0.072764] EVM: security.SMACK64
[ 0.072767] EVM: security.ima
[ 0.072769] EVM: security.capability
[ 0.072996] PM: Registering ACPI NVS region [mem 0x5f6fa000-0x5f6fffff] (24576 bytes)
[ 0.075814] pinctrl core: initialized pinctrl subsystem
[ 0.075982] regulator-dummy: no parameters
[ 0.076063] RTC time: 1:47:14, date: 07/16/14
[ 0.076156] NET: Registered protocol family 16
[ 0.076558] EISA bus registered
[ 0.076563] cpuidle: using governor ladder
[ 0.076566] cpuidle: using governor menu
[ 0.076775] ACPI: bus type PCI registered
[ 0.076782] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.077165] PCI : PCI BIOS area is rw and x. Use pci=nobios if you want it NX.
[ 0.077172] PCI: PCI BIOS revision 2.10 entry at 0xfd982, last bus=3
[ 0.077175] PCI: Using configuration type 1 for base access
[ 0.080060] bio: create slab <bio-0> at 0
[ 0.080394] ACPI: Added _OSI(Module Device)
[ 0.080399] ACPI: Added _OSI(Processor Device)
[ 0.080403] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.080407] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.096627] ACPI: Interpreter enabled
[ 0.096679] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20131115/hwxface-580)
[ 0.096689] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131115/hwxface-580)
[ 0.096719] ACPI: (supports S0 S3 S4 S5)
[ 0.096723] ACPI: Using PIC for interrupt routing
[ 0.096767] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.097048] ACPI: No dock devices found.
[ 0.165105] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.165118] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
[ 0.165131] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.166402] acpi PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.166409] acpi PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.166415] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.166421] acpi PNP0A03:00: host bridge window [mem 0x000d0000-0x000d3fff] (ignored)
[ 0.166426] acpi PNP0A03:00: host bridge window [mem 0x000d4000-0x000d7fff] (ignored)
[ 0.166432] acpi PNP0A03:00: host bridge window [mem 0x000d8000-0x000dbfff] (ignored)
[ 0.166438] acpi PNP0A03:00: host bridge window [mem 0x60000000-0xfebfffff] (ignored)
[ 0.166444] acpi PNP0A03:00: host bridge window [mem 0xfec10000-0xfec1ffff] (ignored)
[ 0.166449] PCI: root bus 00: using default resources
[ 0.166456] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ 0.166752] PCI host bridge to bus 0000:00
[ 0.166760] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.166766] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.166772] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.166791] pci 0000:00:00.0: [8086:3580] type 00 class 0x060000
[ 0.166976] pci 0000:00:00.1: [8086:3584] type 00 class 0x088000
[ 0.167149] pci 0000:00:00.3: [8086:3585] type 00 class 0x088000
[ 0.168153] pci 0000:00:02.0: [8086:3582] type 00 class 0x030000
[ 0.168171] pci 0000:00:02.0: reg 0x10: [mem 0xe8000000-0xefffffff pref]
[ 0.168182] pci 0000:00:02.0: reg 0x14: [mem 0xe0000000-0xe007ffff]
[ 0.168193] pci 0000:00:02.0: reg 0x18: [io 0x1800-0x1807]
[ 0.168238] pci 0000:00:02.0: supports D1
[ 0.168378] pci 0000:00:02.1: [8086:3582] type 00 class 0x038000
[ 0.168394] pci 0000:00:02.1: reg 0x10: [mem 0xf0000000-0xf7ffffff pref]
[ 0.168405] pci 0000:00:02.1: reg 0x14: [mem 0xe0080000-0xe00fffff]
[ 0.168455] pci 0000:00:02.1: supports D1
[ 0.168622] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300
[ 0.168675] pci 0000:00:1d.0: reg 0x20: [io 0x1820-0x183f]
[ 0.168827] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300
[ 0.168880] pci 0000:00:1d.1: reg 0x20: [io 0x1840-0x185f]
[ 0.169036] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300
[ 0.169089] pci 0000:00:1d.2: reg 0x20: [io 0x1860-0x187f]
[ 0.169253] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320
[ 0.169280] pci 0000:00:1d.7: reg 0x10: [mem 0xe0100000-0xe01003ff]
[ 0.169386] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.169541] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060400
[ 0.169706] pci 0000:00:1f.0: [8086:24cc] type 00 class 0x060100
[ 0.169787] pci 0000:00:1f.0: address space collision: [io 0x1000-0x107f] conflicts with ACPI CPU throttle [??? 0x00001010-0x00001015 flags 0x80000000]
[ 0.169796] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH4 GPIO
[ 0.169933] pci 0000:00:1f.1: [8086:24ca] type 00 class 0x01018a
[ 0.169952] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.169966] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.169980] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[ 0.169994] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[ 0.170008] pci 0000:00:1f.1: reg 0x20: [io 0x1810-0x181f]
[ 0.170022] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff]
[ 0.170177] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500
[ 0.170230] pci 0000:00:1f.3: reg 0x20: [io 0x1880-0x189f]
[ 0.170387] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100
[ 0.170407] pci 0000:00:1f.5: reg 0x10: [io 0x1c00-0x1cff]
[ 0.170420] pci 0000:00:1f.5: reg 0x14: [io 0x18c0-0x18ff]
[ 0.170434] pci 0000:00:1f.5: reg 0x18: [mem 0xe0100c00-0xe0100dff]
[ 0.170447] pci 0000:00:1f.5: reg 0x1c: [mem 0xe0100800-0xe01008ff]
[ 0.170502] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.170650] pci 0000:00:1f.6: [8086:24c6] type 00 class 0x070300
[ 0.170671] pci 0000:00:1f.6: reg 0x10: [io 0x2400-0x24ff]
[ 0.170684] pci 0000:00:1f.6: reg 0x14: [io 0x2000-0x207f]
[ 0.170754] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.170919] pci 0000:00:1f.6: System wakeup disabled by ACPI
[ 0.171114] pci 0000:01:00.0: [1180:0476] type 02 class 0x060700
[ 0.171133] pci 0000:01:00.0: proprietary Ricoh MMC controller disabled (via cardbus function)
[ 0.171138] pci 0000:01:00.0: MMC cards are now supported by standard SDHCI controller
[ 0.171155] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff]
[ 0.171187] pci 0000:01:00.0: supports D1 D2
[ 0.171192] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.171318] pci 0000:01:02.0: [10ec:8139] type 00 class 0x020000
[ 0.171340] pci 0000:01:02.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.171354] pci 0000:01:02.0: reg 0x14: [mem 0xe0201000-0xe02010ff]
[ 0.171426] pci 0000:01:02.0: supports D1 D2
[ 0.171431] pci 0000:01:02.0: PME# supported from D1 D2 D3hot D3cold
[ 0.171473] pci 0000:01:02.0: System wakeup disabled by ACPI
[ 0.171553] pci 0000:01:03.0: [8086:4223] type 00 class 0x028000
[ 0.171576] pci 0000:01:03.0: reg 0x10: [mem 0xe0200000-0xe0200fff]
[ 0.171658] pci 0000:01:03.0: PME# supported from D0 D3hot D3cold
[ 0.171793] pci 0000:00:1e.0: PCI bridge to [bus 01-03] (subtractive decode)
[ 0.171802] pci 0000:00:1e.0: bridge window [io 0x3000-0x3fff]
[ 0.171810] pci 0000:00:1e.0: bridge window [mem 0xe0200000-0xe02fffff]
[ 0.171818] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.171823] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.171896] pci_bus 0000:02: busn_res: can not insert [bus 02-ff] under [bus 01-03] (conflicts with (null) [bus 01-03])
[ 0.171906] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.171922] pci_bus 0000:00: on NUMA node 0
[ 0.174396] ACPI: PCI Interrupt Link [LNKA] (IRQs *9)
[ 0.174559] ACPI: PCI Interrupt Link [LNKB] (IRQs *9)
[ 0.174720] ACPI: PCI Interrupt Link [LNKC] (IRQs *9)
[ 0.174879] ACPI: PCI Interrupt Link [LNKD] (IRQs *9)
[ 0.175038] ACPI: PCI Interrupt Link [LNKE] (IRQs *9)
[ 0.175198] ACPI: PCI Interrupt Link [LNKF] (IRQs 9) *0, disabled.
[ 0.175359] ACPI: PCI Interrupt Link [LNKG] (IRQs 9) *0, disabled.
[ 0.175521] ACPI: PCI Interrupt Link [LNKH] (IRQs *9)
[ 0.196418] ACPI: \_SB_.PCI0: notify handler is installed
[ 0.196418] Found 1 acpi root devices
[ 0.196549] ACPI : EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 0.196793] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.196803] vgaarb: loaded
[ 0.196806] vgaarb: bridge control possible 0000:00:02.0
[ 0.197352] SCSI subsystem initialized
[ 0.197438] libata version 3.00 loaded.
[ 0.197497] ACPI: bus type USB registered
[ 0.197550] usbcore: registered new interface driver usbfs
[ 0.197573] usbcore: registered new interface driver hub
[ 0.197621] usbcore: registered new device driver usb
[ 0.197858] PCI: Using ACPI for IRQ routing
[ 0.197894] PCI: pci_cache_line_size set to 64 bytes
[ 0.197958] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[ 0.197963] e820: reserve RAM buffer [mem 0x5f6f0000-0x5fffffff]
[ 0.198185] NetLabel: Initializing
[ 0.198188] NetLabel: domain hash size = 128
[ 0.198191] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.198221] NetLabel: unlabeled traffic allowed by default
[ 0.200212] Switched to clocksource pit
[ 0.217368] AppArmor: AppArmor Filesystem Enabled
[ 0.217459] pnp: PnP ACPI init
[ 0.217516] ACPI: bus type PNP registered
[ 0.219493] system 00:00: [mem 0xfec10000-0xfec1ffff] has been reserved
[ 0.219502] system 00:00: [mem 0x000cd800-0x000cffff] could not be reserved
[ 0.219512] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.220401] system 00:01: [io 0x1000-0x107f] could not be reserved
[ 0.220409] system 00:01: [io 0x1180-0x11bf] has been reserved
[ 0.220416] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.220422] system 00:01: [io 0x0600-0x061f] has been reserved
[ 0.220428] system 00:01: [io 0x0362] has been reserved
[ 0.220435] system 00:01: [io 0x0366] has been reserved
[ 0.220441] system 00:01: [io 0xfe00-0xfe01] has been reserved
[ 0.220448] system 00:01: [io 0x0580-0x0587] has been reserved
[ 0.220455] system 00:01: [mem 0xff800000-0xffffffff] could not be reserved
[ 0.220463] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.220491] pnp 00:02: [dma 4]
[ 0.220538] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.220615] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.220688] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.220752] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.221247] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.222561] pnp 00:07: Plug and Play ACPI device, IDs FJC6001 PNP0f13 (active)
[ 0.244777] pnp 00:08: Plug and Play ACPI device, IDs WACf004 PNP0501 (active)
[ 0.259049] pnp: PnP ACPI: found 9 devices
[ 0.259054] ACPI: bus type PNP unregistered
[ 0.259063] PnPBIOS: Disabled by ACPI PNP
[ 0.297452] Switched to clocksource acpi_pm
[ 0.297493] pci 0000:01:00.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000
[ 0.297504] pci 0000:00:1e.0: bridge window [mem 0x04000000-0x03ffffff pref] to [bus 01-03] add_size 4000000
[ 0.297516] pci 0000:00:1f.0: BAR 13: [io 0x1000-0x107f] has bogus alignment
[ 0.297526] pci 0000:00:1e.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000
[ 0.297540] pci 0000:00:1e.0: BAR 15: assigned [mem 0x60000000-0x63ffffff pref]
[ 0.297548] pci 0000:00:1f.1: BAR 5: assigned [mem 0x64000000-0x640003ff]
[ 0.297566] pci 0000:01:00.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000
[ 0.297572] pci 0000:01:00.0: res[16]=[mem 0x04000000-0x03ffffff] get_res_add_size add_size 4000000
[ 0.297578] pci 0000:01:00.0: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size 100
[ 0.297584] pci 0000:01:00.0: res[14]=[io 0x0100-0x00ff] get_res_add_size add_size 100
[ 0.297593] pci 0000:01:00.0: BAR 0: assigned [mem 0x68000000-0x68000fff]
[ 0.297602] pci 0000:01:00.0: BAR 15: assigned [mem 0x60000000-0x63ffffff pref]
[ 0.297610] pci 0000:01:00.0: BAR 16: assigned [mem 0x6c000000-0x6fffffff]
[ 0.297616] pci 0000:01:00.0: BAR 13: assigned [io 0x3400-0x34ff]
[ 0.297622] pci 0000:01:00.0: BAR 14: assigned [io 0x3800-0x38ff]
[ 0.297629] pci 0000:01:00.0: CardBus bridge to [bus 02]
[ 0.297634] pci 0000:01:00.0: bridge window [io 0x3400-0x34ff]
[ 0.297642] pci 0000:01:00.0: bridge window [io 0x3800-0x38ff]
[ 0.297650] pci 0000:01:00.0: bridge window [mem 0x60000000-0x63ffffff pref]
[ 0.297657] pci 0000:01:00.0: bridge window [mem 0x6c000000-0x6fffffff]
[ 0.297665] pci 0000:00:1e.0: PCI bridge to [bus 01-03]
[ 0.297672] pci 0000:00:1e.0: bridge window [io 0x3000-0x3fff]
[ 0.297681] pci 0000:00:1e.0: bridge window [mem 0xe0200000-0xe02fffff]
[ 0.297689] pci 0000:00:1e.0: bridge window [mem 0x60000000-0x63ffffff pref]
[ 0.297701] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.297706] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.297712] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.297718] pci_bus 0000:01: resource 1 [mem 0xe0200000-0xe02fffff]
[ 0.297724] pci_bus 0000:01: resource 2 [mem 0x60000000-0x63ffffff pref]
[ 0.297729] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.297734] pci_bus 0000:01: resource 5 [mem 0x00000000-0xffffffff]
[ 0.297740] pci_bus 0000:02: resource 0 [io 0x3400-0x34ff]
[ 0.297745] pci_bus 0000:02: resource 1 [io 0x3800-0x38ff]
[ 0.297751] pci_bus 0000:02: resource 2 [mem 0x60000000-0x63ffffff pref]
[ 0.297757] pci_bus 0000:02: resource 3 [mem 0x6c000000-0x6fffffff]
[ 0.297839] NET: Registered protocol family 2
[ 0.298263] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.298313] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.298401] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.298457] TCP: reno registered
[ 0.298464] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.298487] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.298625] NET: Registered protocol family 1
[ 0.298664] pci 0000:00:02.0: Boot video device
[ 0.298934] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 9
[ 0.298940] PCI: setting IRQ 9 as level-triggered
[ 0.299194] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
[ 0.299442] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 9
[ 0.299691] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 9
[ 0.299848] PCI: CLS 32 bytes, default 64
[ 0.299965] Trying to unpack rootfs image as initramfs...
[ 1.563071] Freeing initrd memory: 26956K (f4b4a000 - f659d000)
[ 1.563374] Simple Boot Flag at 0x41 set to 0x1
[ 1.563707] microcode: CPU0 sig=0x6d8, pf=0x20, revision=0x20
[ 1.563895] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.563901] Scanning for low memory corruption every 60 seconds
[ 1.564559] Initialise system trusted keyring
[ 1.564678] audit: initializing netlink socket (disabled)
[ 1.564707] type=2000 audit(1405475235.561:1): initialized
[ 1.617490] bounce pool size: 64 pages
[ 1.617514] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.621212] VFS: Disk quotas dquot_6.5.2
[ 1.621330] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.622495] fuse init (API version 7.22)
[ 1.622684] msgmni has been set to 1728
[ 1.622827] Key type big_key registered
[ 1.623358] Key type asymmetric registered
[ 1.623363] Asymmetric key parser 'x509' registered
[ 1.623449] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.623506] io scheduler noop registered
[ 1.623510] io scheduler deadline registered (default)
[ 1.623580] io scheduler cfq registered
[ 1.623865] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.623903] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.624050] efifb: probing for efifb
[ 1.624058] efifb: cannot reserve video memory at 0xa0000
[ 1.624065] efifb: framebuffer at 0xa0000, mapped to 0xc00a0000, using 64k, total 64k
[ 1.624070] efifb: mode is 640x480x1, linelength=80, pages=1
[ 1.624072] efifb: scrolling: redraw
[ 1.624077] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.627755] Console: switching to colour frame buffer device 80x30
[ 1.631302] fb0: EFI VGA frame buffer device
[ 1.631345] intel_idle: does not run on family 6 model 13
[ 1.631362] ipmi message handler version 39.2
[ 1.634068] ACPI: AC Adapter [AC] (on-line)
[ 1.634438] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 1.634450] ACPI: Power Button [PWRB]
[ 1.634626] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input1
[ 1.646891] ACPI: Lid Switch [LID]
[ 1.646995] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.647002] ACPI: Power Button [PWRF]
[ 1.647155] tsc: Marking TSC unstable due to TSC halts in idle
[ 1.647169] ACPI: acpi_idle registered with cpuidle
[ 1.659070] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.659075] ACPI: Thermal Zone [TZC] (53 C)
[ 1.659161] GHES: HEST is not enabled!
[ 1.659339] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.679870] 00:08: ttyS4 at I/O 0x148 (irq = 4, base_baud = 115200) is a 16550A
[ 1.680220] isapnp: Scanning for PnP cards...
[ 1.734690] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
[ 1.735170] Linux agpgart interface v0.103
[ 1.735281] agpgart-intel 0000:00:00.0: Intel 855GM Chipset
[ 1.735348] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[ 1.736803] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.737042] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 1.742805] brd: module loaded
[ 1.746663] loop: module loaded
[ 1.747142] ata_piix 0000:00:1f.1: version 2.13
[ 1.747167] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 1.793104] scsi0 : ata_piix
[ 1.793241] scsi1 : ata_piix
[ 1.793369] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1810 irq 14
[ 1.793374] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1818 irq 15
[ 1.794193] libphy: Fixed MDIO Bus: probed
[ 1.794457] tun: Universal TUN/TAP device driver, 1.6
[ 1.794461] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.795111] PPP generic driver version 2.4.2
[ 1.795268] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.795280] ehci-pci: EHCI PCI platform driver
[ 1.795398] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.795412] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.795433] ehci-pci 0000:00:1d.7: debug port 1
[ 1.799362] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[ 1.799417] ehci-pci 0000:00:1d.7: irq 9, io mem 0xe0100000
[ 1.799689] ata2: port disabled--ignoring
[ 1.843460] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.843650] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.843656] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.843662] usb usb1: Product: EHCI Host Controller
[ 1.843667] usb usb1: Manufacturer: Linux 3.13.0-24-generic ehci_hcd
[ 1.843672] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.843897] hub 1-0:1.0: USB hub found
[ 1.843917] hub 1-0:1.0: 6 ports detected
[ 1.844288] ehci-platform: EHCI generic platform driver
[ 1.844309] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.844312] ohci-pci: OHCI PCI platform driver
[ 1.844336] ohci-platform: OHCI generic platform driver
[ 1.844354] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.844443] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.844454] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.844492] uhci_hcd 0000:00:1d.0: irq 9, io base 0x00001820
[ 1.844599] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.844605] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.844610] usb usb2: Product: UHCI Host Controller
[ 1.844615] usb usb2: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.844620] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.844830] hub 2-0:1.0: USB hub found
[ 1.844847] hub 2-0:1.0: 2 ports detected
[ 1.845087] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.845099] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.845126] uhci_hcd 0000:00:1d.1: irq 9, io base 0x00001840
[ 1.845216] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.845222] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.845228] usb usb3: Product: UHCI Host Controller
[ 1.845233] usb usb3: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.845238] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.845442] hub 3-0:1.0: USB hub found
[ 1.845458] hub 3-0:1.0: 2 ports detected
[ 1.845703] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.845715] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.845743] uhci_hcd 0000:00:1d.2: irq 9, io base 0x00001860
[ 1.845832] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.845839] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.845844] usb usb4: Product: UHCI Host Controller
[ 1.845849] usb usb4: Manufacturer: Linux 3.13.0-24-generic uhci_hcd
[ 1.845854] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.846064] hub 4-0:1.0: USB hub found
[ 1.846080] hub 4-0:1.0: 2 ports detected
[ 1.846402] i8042: PNP: PS/2 Controller [PNP0303:K101,FJC6001:MOU1] at 0x60,0x64 irq 1,12
[ 1.848546] i8042: Detected active multiplexing controller, rev 1.1
[ 1.893614] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.893625] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.893691] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.893748] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.893798] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.894014] mousedev: PS/2 mouse device common for all mice
[ 1.894326] rtc_cmos 00:04: RTC can wake from S4
[ 1.894481] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.894504] rtc_cmos 00:04: alarms up to one month, y3k, 114 bytes nvram
[ 1.894663] device-mapper: uevent: version 1.0.3
[ 1.938373] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[ 1.938417] platform eisa.0: Probing EISA bus 0
[ 1.938430] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.938437] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.938443] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 1.938480] platform eisa.0: EISA: Detected 0 cards
[ 1.938492] cpufreq-nforce2: No nForce2 chipset.
[ 1.938499] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.938832] TCP: cubic registered
[ 1.939086] NET: Registered protocol family 10
[ 1.939537] NET: Registered protocol family 17
[ 1.939557] Key type dns_resolver registered
[ 1.939887] Using IPI No-Shortcut mode
[ 1.940079] Loading compiled-in X.509 certificates
[ 2.036815] Loaded X.509 cert 'Magrathea: Glacier signing key: 77d70e1df42996dc92b01d759d3e8562ea32a1c7'
[ 2.036855] registered taskstats version 1
[ 2.041312] Key type trusted registered
[ 2.088582] isapnp: No Plug & Play device found
[ 2.088825] Key type encrypted registered
[ 2.091623] ata1.00: ATA-6: HTS541080G9AT00, MB4OA60A, max UDMA/100
[ 2.091631] ata1.00: 156301488 sectors, multi 16: LBA48
[ 2.093644] AppArmor: AppArmor sha1 policy hashing enabled
[ 2.093651] IMA: No TPM chip found, activating TPM-bypass!
[ 2.093988] regulator-dummy: disabling
[ 2.094062] Magic number: 6:546:761
[ 2.094215] rtc_cmos 00:04: setting system clock to 2014-07-16 01:47:16 UTC (1405475236)
[ 2.094531] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 2.094535] EDD information not available.
[ 2.094625] PM: Hibernation image not present or could not be loaded.
[ 2.104549] ata1.00: configured for UDMA/100
[ 2.105366] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 2.290767] ACPI: Battery Slot [BATA] (battery present)
[ 2.291037] scsi 0:0:0:0: Direct-Access ATA HTS541080G9AT00 MB4O PQ: 0 ANSI: 5
[ 2.291372] sd 0:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 2.291489] sd 0:0:0:0: [sda] Write Protect is off
[ 2.291496] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.291548] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.292084] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.338987] sda: sda1 sda2 < sda5 >
[ 2.339545] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.340217] Freeing unused kernel memory: 872K (c19ae000 - c1a88000)
[ 2.340306] Write protecting the kernel text: 6512k
[ 2.340465] Write protecting the kernel read-only data: 2756k
[ 2.340468] NX-protecting the kernel data: 5776k
[ 2.368321] systemd-udevd[96]: starting version 204
[ 2.431495] ACPI: Video Device [GRFX] (multi-head: yes rom: no post: no)
[ 2.439581] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input8
[ 2.547306] [drm] Initialized drm 1.1.0 20060810
[ 2.585338] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 2.585392] 8139cp 0000:01:02.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 2.673948] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 2.674769] 8139too 0000:01:02.0 eth0: RealTek RTL8139 at 0x00013000, 00:0b:97:2e:74:89, IRQ 9
[ 2.995614] [drm] Memory usable by graphics device = 128M
[ 2.995626] checking generic (a0000 10000) vs hw (e8000000 8000000)
[ 2.995630] fb: conflicting fb hw usage inteldrmfb vs EFI VGA - removing generic driver
[ 2.995663] Console: switching to colour dummy device 80x25
[ 3.000539] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.000547] [drm] Driver supports precise vblank timestamp query.
[ 3.000661] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.060045] [drm] GMBUS [i915 gmbus panel] timed out, falling back to bit banging on pin 3
[ 3.085133] [drm] initialized overlay support
[ 3.188524] fbcon: inteldrmfb (fb0) is primary device
[ 3.391497] psmouse serio4: alps: Unknown ALPS touchpad: E7=10 00 64, EC=10 00 64
[ 3.952187] Console: switching to colour frame buffer device 128x48
[ 3.959590] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 3.959595] i915 0000:00:02.0: registered panic notifier
[ 3.959614] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 4.180131] input: PS/2 Generic Mouse as /devices/platform/i8042/serio4/input/input12
[ 4.476679] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.866170] random: nonblocking pool is initialized
[ 20.110601] Adding 513020k swap on /dev/sda5. Priority:-1 extents:1 across:513020k FS
[ 20.237568] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.529854] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 20.537305] systemd-udevd[329]: starting version 204
[ 20.818470] lp: driver loaded but no devices found
[ 20.874977] ppdev: user-space parallel port driver
[ 21.274993] input: Panasonic Laptop Support as /devices/virtual/input/input13
[ 21.418992] intel_rng: FWH not detected
[ 21.526374] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 21.808672] ACPI Warning: 0x000011b0-0x000011bf SystemIO conflicts with Region \_SB_.SID0 1 (20131115/utaddress-251)
[ 21.808690] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 21.808695] ACPI Warning: 0x00001180-0x000011af SystemIO conflicts with Region \_SB_.SID0 1 (20131115/utaddress-251)
[ 21.808703] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 21.808707] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 22.553583] Bluetooth: Core ver 2.17
[ 22.554604] NET: Registered protocol family 31
[ 22.554610] Bluetooth: HCI device and connection manager initialized
[ 22.554627] Bluetooth: HCI socket layer initialized
[ 22.554633] Bluetooth: L2CAP socket layer initialized
[ 22.554651] Bluetooth: SCO socket layer initialized
[ 22.684604] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.684613] Bluetooth: BNEP filters: protocol multicast
[ 22.684635] Bluetooth: BNEP socket layer initialized
[ 22.695015] cfg80211: Calling CRDA to update world regulatory domain
[ 22.699920] Bluetooth: RFCOMM TTY layer initialized
[ 22.699966] Bluetooth: RFCOMM socket layer initialized
[ 22.699979] Bluetooth: RFCOMM ver 1.11
[ 22.828696] lib80211: common routines for IEEE802.11 drivers
[ 22.828709] lib80211_crypt: registered algorithm 'NULL'
[ 22.979375] yenta_cardbus 0000:01:00.0: CardBus bridge found [10f7:8338]
[ 23.106603] yenta_cardbus 0000:01:00.0: ISA IRQ mask 0x0cb8, PCI irq 9
[ 23.106616] yenta_cardbus 0000:01:00.0: Socket status: 30000006
[ 23.106630] yenta_cardbus 0000:01:00.0: pcmcia: parent PCI bridge window: [io 0x3000-0x3fff]
[ 23.106637] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff:
[ 23.165152] libipw: 802.11 data/management/control stack, git-1.1.13
[ 23.165163] libipw: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
[ 23.254785] init: cups main process (492) killed by HUP signal
[ 23.254812] init: cups main process ended, respawning
[ 23.107923] excluding 0x3000-0x30ff 0x3400-0x34ff 0x3800-0x38ff
[ 23.347917] yenta_cardbus 0000:01:00.0: pcmcia: parent PCI bridge window: [mem 0xe0200000-0xe02fffff]
[ 23.347929] pcmcia_socket pcmcia_socket0: cs: memory probe 0xe0200000-0xe02fffff:
[ 23.347934] excluding 0xe0200000-0xe020ffff
[ 23.347957] yenta_cardbus 0000:01:00.0: pcmcia: parent PCI bridge window: [mem 0x60000000-0x63ffffff pref]
[ 23.347963] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x63ffffff:
[ 23.347988] excluding 0x60000000-0x63ffffff
[ 23.446871] device-mapper: multipath: version 1.6.0 loaded
[ 23.572549] ipw2200: Intel(R) PRO/Wireless 2200/2915 Network Driver, 1.2.2kmprq
[ 23.572558] ipw2200: Copyright(c) 2003-2006 Intel Corporation
[ 23.572840] ipw2200: Detected Intel PRO/Wireless 2915ABG Network Connection
[ 24.686115] init: failsafe main process (572) killed by TERM signal
[ 24.731279] ipw2200: Detected geography ZZA (11 802.11bg channels, 13 802.11a channels)
[ 25.065257] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af:
[ 25.066196] excluding 0x148-0x14f 0x170-0x177 0x1f0-0x1f7 0x360-0x367 0x370-0x377
[ 25.066981] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff:
[ 25.067358] excluding 0x3f0-0x3f7 0x4d0-0x4d7
[ 25.067721] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff:
[ 25.084828] clean.
[ 25.084915] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7:
[ 25.085559] clean.
[ 25.085599] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff:
[ 25.085610] excluding 0xc0000-0xcffff 0xdc000-0xfffff
[ 25.085658] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff:
[ 25.085688] clean.
[ 25.085717] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff:
[ 25.085740] excluding 0x60000000-0x60ffffff
[ 25.085772] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff:
[ 25.086435] clean.
[ 25.153504] cfg80211: World regulatory domain updated:
[ 25.153516] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 25.153521] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 25.153526] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 25.153530] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 25.153534] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 25.153539] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 26.128051] intel8x0_measure_ac97_clock: measured 55279 usecs (2663 samples)
[ 26.128061] intel8x0: clocking to 48000
[ 27.162206] init: samba-ad-dc main process (732) terminated with status 1
[ 27.772707] 8139too 0000:01:02.0 eth0: link down
[ 27.779531] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.783139] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.084828] clean.
[ 25.085559] clean.
[ 25.085688] clean.
[ 25.086435] clean.
Jeff should be able to sort out your Terminal after typing in dmesg, however the front buttons are a story for another day and time. Concerning the "restart" issue, from Ubuntu 10.10 to Linux Mint 17 is a giant leap in space. If the "restart" issue is happening back in 10.10, and continuing now that is one major issue to sort, probably hardware based. I'm thinking something current, something light i.e. xfce (see above), or Lubuntu: http://lubuntu.net/
but that is 14, maybe take a step back to 12 or so: http://lubuntu.net/blog/lubuntu-1204-now-available
Seriously, after trying some of the older model Toughbooks & Linux, you need to search for what works for you. Yes, it is a pain to get something that sort of works, but then have to do things manually. Last resort, try what I am using, this is the newest: http://navigatrix.net/index.php
However, an older version works better for the CF-28:
http://navigatrix.net/viewtopic.php?f=4&t=643
look for post # 8 to find the download iso.
Hope things work out for you
Where did they put the error log? Was that the whole thing that you sent?
I'm trying to find the section where restart is activated. Does yours look anything like the below.
cd@cd-CF-19CDBAXVM ~ $ dmesg | grep input
[ 2.232331] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input0
[ 2.247144] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
[ 2.247296] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 3.332456] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 3.539632] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input8
[ 4.970709] input: PS/2 Generic Mouse as /devices/platform/i8042/serio4/input/input12
[ 13.806629] input: Panasonic Laptop Support as /devices/virtual/input/input13
[ 14.906816] input: Wacom ISDv4 90 Pen as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input14
[ 15.617349] inputs:
[ 15.662675] inputs:
[ 15.669514] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 15.669815] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
Funny. I'm getting that in my CF-29 Mk-5 but with a straight Debian. The same OS in my Mk-3 reboots fine.
If you get as far as a black screen, the OS has probably done its job already and initiated shutdown + reset register set to signal the hardware. In my case I suspect some motherboard component hanging and can't flip from reset to bootstrap and won't pass to the next component in the chain. I'll have to experiment a bit.
Edit: I missed that part in the OP where you say that the behaviour is different between clicking a button and typing reboot. Ignore the above then. I would attempt to figure out what the restart button in your shutdown menu does so differently than a reboot command.
Jeff: you're in a better position to check that out since I don't run Mint. Should be trivial to figure out what the menu is doing.
Jeff,
That is the extent of my file. I'll look at it again tonight to see if there is any difference or anything that looks like what you showed.
Mark
Mark
