Here we go again. A CF-19 MK4 magically appeared on my lap recently and the bloody thing is running hot. Do I really have to dismantle the thing down to its base elements in order to slap on some fujipoly?
Warm day, on a table, in a pub, bear on the right, food on the left. It's at 61 degrees C.
Thermal pad replacement. Do it right.
Re: Thermal pad replacement. Do it right.
Yes, full disassembly is required.kode-niner wrote: bear on the right, food on the left. ...
I suggest that you let the BEAR have the food and you RUN LIKE HELLL..
Shawn, if it's the Hamm's bear then it's okay, Kode-niner is in a pub after all.
- IMG_0014.PNG (41.52 KiB) Viewed 17546 times
We get some rules to follow.
CF-20 Mk1, CF-31 Mk5 i7, CF-31 Mk6 i7, FZ-G1 Mk2, CF-54 Mk2, CF-29 Mk5, CF-74J,
How the hell did that one get past editing?
I hope your code is edited better.......
