2. When re-installing the bottom cover....if the cover does not fit down neatly...check that one of said wlan cables isn't in the way.....like it pulled loose from the 2100 card and is laying in the wrong place.
Yah, yah I know....2100 is no good,, but if Linux sees it, it runs it. (Unless the cable is loose)
So far I have tried seven installs. They all crashed. Why? Because the WLAN was not working. See #1 and #2. The system (Linux) will crash when it looks for the internet...........waiting for Lubuntu to finish....before posting this................................................................................
If I have problems later I will post. Meanwhile Lubuntu iis dandy. I ike the blue color.
