bios pass mk5
bios pass mk5
So can I get rid of a bios pass on a CF-18N? A guy I deal with has them and I still can sell the heck out of them,thanks.
Re: bios pass mk5
Nope...I know others have tried but no go. As you know by now Toughbooks are not like most laptops.  We have tried running many programs to remove the password and no go.
- Springfield
Re: bios pass mk5
I think so, but not certain. Believe CF-18 works the same as CF-29 -- pull battery & CMOS battery, then hold the power switch ON for 30 seconds a few times to drain mobo capacitors. Power up with AC adapter to make sure CMOS has reset, then plug it all back in. Might try it with a spare CF-18N to make sure before investing in a lot . . .
Re: bios pass mk5
There were some posts that had luck if they removed the RAM out as well.  Maybe try that.
							-Claes
There can only be one!
Re: bios pass mk5
If any of these tricks work please let us know
Re: bios pass mk5
I may end up with one minus bios pass and will try it,but I'm gonna pass on the locked ones. Thanks everyone.
