Bios problem
Re: Bios problem
thanks Jeff but my problem is I cannot load the bios in windows using the normal windows software I get a error I need a bios that I can load in dos as I have a non standard bios there are many posts around about this but I cannot find the correct files to change my bios
Re: Bios problem
Here's a shot in the dark. This is an old post from NBR. FWIW
tepifan tepifan is offline
Newbie
Join Date
Apr 2011
Posts
1
Rep Power
0
Default Re: CF-19 Mk 1 Win 7 problems
Quote Originally Posted by jvoelcker View Post
OK, definitely not a dual screen
OK, managed to make some progress - it seems that I have a custom model with a custom BIOS that needs to be updated before the touchscreen will be recognised properly.
Unfortunately the bios seems to be locked so that it cannot be updated.
I think this is the end of the line, but will do some digging to see if it is possible to bypass the update lockout - either by locating intermediate BIOS updates to see if they work or by looking at hardware options to see if there are any switches on the motherboard.
I have V1.00L13 M14 BIOS and have been trying to run the windows based XP to Vista BIOS update bios_19_1_r070207.exe that fails with error 'This program will not run on this PC'.
From talking to some others in the know I may be able to get a bit further with the older DOS based BIOS update utility, but I can't find older versions to download.
Do any of you have some intermediary BIOS files that I can try to install?
Thanks.
Dunno if you still need those BIOS files but some how I managed to find them, worked wonders for me...flashed from a bootable USB after upgrading to Windows 7 and it solved all my issues for the touch screen. Totally recognized now Hit me up at Tepifan at gmail.com if you need them.
Share
| Like
Re: Bios problem
thanks ive sent him a email to see if he still has the files
Re: Bios problem
If you get those files, please let me know...I would like a copy of them...Tazmadman wrote:thanks ive sent him a email to see if he still has the files
Re: Bios problem
yeh as soon as I here ill let you know
