CF-19 MK3 BIOS question
RDClaes
Re: CF-19 MK3 BIOS question
#11 Post by RDClaes »
toughasnails wrote:
mklym wrote: You should be good now. :D
mklym is right , you need no BIOS update for you 19 . The 30MK1 and the 19MK1 was the only ones that needed the update.
I'm not sure that is correct, I'll PM you some specifics
-Claes
There can only be one!
RDJacob
#12 Post by RDJacob »
So after extensive CF-19 Bios flashing tests I found that in order to have full functionality with all devices, the BIOS file being used to write with has to come from the exact model as the unit getting flashed, down to the specific letter/number.
#13 Post by ADOR »
I just did Windows 7 this time home on two Mk1 CF-74's. They needed a bios update also to get touch, sound, etc working.
liamw652
#14 Post by liamw652 »
And this is interesting, my cf-19k4 with W7 is running the v3.00L19 bios and everything works fine. All the front buttons, everything
Bill
CF-29 M Touch
CF-30 Mk1 Touch
CF-19 Mk3 Touch
