Me too mate It's taken me forever to get round to sorting this outmklym wrote:I hope it works out for you.
Asus Gobi 2000 Card Drivers
Re: Asus Gobi 2000 Card Drivers
Right then here goes
The Gobi2000 module arrived which I have fitted into the ToughBook and installed as per the drivers I was provided in this thread.
I'm not entirely sure that the module installed correctly as once the setup had completed the module doesn't display under the Network Adapters section like the Gobi1000 module does and the only trace of it I can find is under Ports as per the picture below, device manager also keep refreshing every 3-4 seconds as well when the setup has finished and doesn't stop doing this until the module has been removed.
I read the readme file in the folder with the driver and I have attempted to use some of the command line switches such as /WIN7DRIVER=1 and /GPS=1 however, this doesn't seem to make a difference.
Can someone point me in the right direction, I feel like I'm getting somewhere but not fast lol
I'd also like to know what I'll have to use to establish a 3G connection and use the GPS feature as at the moment with the Gobi100 I'm using ToughConnect
Two little updates, I've been tinkering with it and still unable to get this installed and working
It's driving be crazy!!!!!
I've tried the Panasonic Carrier Selection Software and it didn't work, I just got the COM11 flash on, flash off, flash on, flash off game again
Also, the dip switches next to the Mini PCI-E slot, will they need changing for the GOBI2000 module as it is currently configured for WWAN1, there is WWAN2 and 3 as well
I eagerly await your replies
When I used Fujitsu Gobis (CF-30,19, 52 even a CF-29 on the sled) I used Fujitsus installer. Quick and clean.
My advise is use the ASUS installer. (they have one???) First I would delete anything Gobi from the control panel. Then pull power and re-set by holding the switch on a few times. Drains the capacitors or something..
My install on a rev A sled I had to play with dip switches. 29 and 30.
IOW don't use the pana package. It reads the # on the card and throws you out or ignores you.
As I remember Fujitsu wanted to install with Gobi on. You will have four devices added to device manager.
I wonder if the Fujitsu installer would work for you?
I'll look some other stuff up when I find the dual boot 52.
Right click the Qualcomm gobi in device manager, go to properties, DETAILS tab and scroll down one to Hardware I.D. When I was sorting this mess I used the USB/PID? number to search for the Gobi Package that I used.
My idea is that number is the one the Pana package checks just before it quits you. I made this up....trial and error....I have no reference to look up for it. Good luck.
Thanks for the reply, I've downloaded the Fujitsu Sierra Wireless driver package from their website and will be trying this shortlySadlmkr wrote:When I used Fujitsu Gobis (CF-30,19, 52 even a CF-29 on the sled) I used Fujitsus installer. Quick and clean.
Do you know what the 4 dip switches need to be set to for use with the Gobi2000 module?
No good
Fujitsu package just installs the software and leaves the Qualcomm Gobi 2000 with a yellow ? in Device Manager
How can this be so hard, I though if I had the right card with the right SKU then it should be plug and play as I was under the impression that the Mk4 CF-19 came with the Gobi2000 as standard
Here is a shot of my Device Manager in my CF-19MK4 with a GOBI2000 installed.
I used software from Panasonic Canada. There was the firmware, 72-VT647-23-Panasonic Gobi 1.1.260.zip and OneClickInternet_Sierra_20101028_v1.9.zip.
Is the SKU the same as the one I posted?
Check in the properties for the hardware ID.
Oh, gotto go. TTYL.
Oh, gotto go. TTYL.
I thought it was five instead of four. Two in com, one in modem....well here's a picture.
It's obvious that mklym has a Panasonic package.
I'll pull the sled and tell you dip switches after feeding the sheepies.
- cf30gobi.PNG (30.15 KiB) Viewed 9006 times
Appreciated guys I only get the one COM install and that's it :s
Nice one on the dip switch config
And yes its the correct SKU
OK I see a difference. Yours shows 250E. Panasonic 250F. Fuj is 9001. What's that mean. Google time.
Scary drivers sites showed up....I never hardly ever use them. Prefer "official" sites.
- gobi3.PNG (28 KiB) Viewed 8998 times
- gobi2.PNG (14.36 KiB) Viewed 8998 times
