Before I start let me say: Forgive me Toughbook geeks as I have sinned! This is what I bought and will return today: http://www.microsoftstore.com/store/msu ... .289564800
To start, let me explain WHY I tried this out:
1) Toughbooks are HEAVY units
2) Toughbook screens are lower end compared to the competition
Things I overlooked when I bought this Samsung ATIV 9 Plus:
1) No Verizon 4G built in
2) No digitizer for my one note notes
Why did I buy this?
1) The screen res is 3200x1800... Which, BTW is SO HIGH that you have to have everything at 200% zoom anyways! It's not practical! It's actually TOO high of a res! I had to scale it back to 1920x1200 or 1920x1080 while using my terminal for my work, defeating the entire point of having such a nice, beautiful screen. All in all, this Samsung is BADASS for a normal, consumer who doesn't mind not having a digitizer or a Verizon card built in. I even considered going back to my H1 for my notes portion, which I thought about and decided that I'm NOT taking steps BACKWARDS!
At any rate, I'm returning it and going back to my trusty C2. Although, I AM going to put Windows 8.1 on it!
In the future when I can get a G1 for cheap I'll most likely switch to that and get a jumpseat keyboard from iKey for it. Can't drop $3000 right now though!
That is it!
And so I attempted to switch to a Samsung Ultrabook...
Re: And so I attempted to switch to a Samsung Ultrabook...
Admitting it is the first step to recovery...
Maybe we should turn this into a screen hack thread for a toughbook. Find a screen that will fit with a higher resolution.
CF-MX3
Processor
Premium Model: Intel Core i7-4600U vPro Processor
(2.0GHz, Turbo Boost to 3.30GHz)
Local Model: Intel Core i5-4200U 1.6GHz Processor
Memory
Premium Model: 8GB DDR3L RAM
Local Model: 4GB DDR3L RAM
Optical Drive
DVD Super-Multi Drive
Display (External)
Max 1920x1200 (1920x1080 in mirror mode)
Integrated Ports
2x USB 3.0
1x VGA
1x HDMI
1x RJ-45/Ethernet
1x SDXC slot
Mic-in mini jack (stereo)
Audio-out mini jack
Capacitive stylus
Power
Use time: Approximately 14.5 hours
Charge time: Approximately 4 hours
Battery: Removable
Operating System
64-bit English Windows 8.1 Professional
Graphics
Intel HD Graphics 4400
Shared VRAM up to 1792MB
Storage
Premium Model: 512GB SSD
Local Model: 128GB SSD
Display (Internal)
12.5" TFT Multitouch LCD IPS
1920x1080
16.7 million colors
Communication
Lan: 1000BASE-T/100BASE-TX/10BASE-T
Wifi: Intel Dual-Band AC-7620
801.22a/b/g/n/ac compliant
Bluetooth: Version 4.0
Input/Output
1080p Front-facing webcam
PCM sound source (stereo 24-bit)
Intel HD Audio compliant mono speaker
Mono microphone
Physical Features
301x210x21mm (11.85x8.26x.826in)
Notebook: 1.198kg (2.64 lb)
AC Adapter: .185kg (.4 lb)
Other
Ambient light sensor, geomagnetic sensor, gyro sensor, accelerometer
Processor
Memory
Optical Drive
Display (External)
Integrated Ports
2x USB 3.0
1x VGA
1x HDMI
1x RJ-45/Ethernet
1x SDXC slot
Audio-out mini jack
Capacitive stylus
Power
Battery: Removable
Operating System
Graphics
Storage
Display (Internal)
1920x1080
16.7 million colors
Communication
Input/Output
Mono microphone
Physical Features
Other
"Capacitive stylus" ... NO!!!!!!!
that ~6MP resolution on a 13.3" is insane ! (even more when you compare it to 1024x768 ~0.8MP)
Maybe a graphic designer/photoshopper would appreciate it on the move...
Anyways, that MX3 sounds really nice, it's very light and 14.5h runtime is a looong time.
C1mk1&2, CF19mk4, CF30mk1&mk3
