BIOS Password
Re: BIOS Password
Unplugging the cmos battery never fail me. I used this method from MK1-MK5 and its all sucess. i wonder why or maybe something not right.
- twillingham
Re: BIOS Password
still stumped I did it step by step then left disconnected all night. Nothing.
Re: BIOS Password
Did you get my email about the other programs
Blair
Blair
Blair
- twillingham
Re: BIOS Password
I got the download burned the cd. Wow what an awesome array of utilities and programs But the BIOS ones did not work. The problem is that the passwords they give you are too long for the most part. There are only seven character to input.
Re: BIOS Password
I found their is a lot of good programs on it and was going to try it but my cd-rom pack is not bootable at the moment.I was going to put a password in and try some of the things you did to see what went wrong but it would mean for me to swap out the burner and at the moment I have no time too but maybe this weekend
Blair
Blair
Blair
Re: BIOS Password
Did you try this one
http://www.cgsecurity.org/wiki/CmosPwd
This one should be on the Hiren Boot CD .
CmosPwd
From CGSecurity
CmosPwd decrypts password stored in cmos used to access BIOS SETUP.
Works with the following BIOSes
ACER/IBM BIOS
AMI BIOS
AMI WinBIOS 2.5
Award 4.5x/4.6x/6.0
Compaq (1992)
Compaq (New version)
IBM (PS/2, Activa, Thinkpad)
Packard Bell
Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
Phoenix 4 release 6 (User)
Gateway Solo - Phoenix 4.0 release 6
Toshiba
Zenith AMI
With CmosPwd, you can also backup, restore and erase/kill cmos.
AWARD 4.50 have a backdoor, a generic password : AWARD_SW SOYO motherboard have "SY_MB" as master password for Award 4.51. CmosPwd give equivalent passwords for Award BIOS, not original one. For more information, ReadMe
Blair
CmosPwd
From CGSecurity
ACER/IBM BIOS
AMI BIOS
AMI WinBIOS 2.5
Award 4.5x/4.6x/6.0
Compaq (1992)
Packard Bell
Toshiba
Zenith AMI
Blair
Blair
- gray-beard
Re: BIOS Password
OK try this,,,,,
Remove the main battery.
Unplug the bios battery.
Connect the power supply, turn on the computer, wait till it boots and then pull the power supply plug and let it die,,,,,
I normally do this about 3 0r 4 times.
Plug back in the bios battery and the main battery and access the bios.
This has always worked for me on CF-27, CF-28, CF-29.
Bob
Bob
- psych0Thrasher
- Contact:
Re: BIOS Password
I went through about 120 29s mk2 and mk4 and did what Alex does cept I hold the power button for about 10 seconds with all other power cut off. Then boot and open bios and save and shut down reconnect and you should be good to go. (btw you can get to the bio battery through the hard drive compartment, if you have a steady hand and a tiny flat head screwdriver you can save yourself alot of time. don't poke around in there with the battery or ac plugged in though)
Dan
Dan
- twillingham
Re: BIOS Password
thanks
Re: BIOS Password
the cmos batt is not under the memory cover, it is on the other side of the board. near the touchpad cable. EDIT sorry i didnt notice the date on the post
