Is Internal 802.11N available for CF-51 Duo Core, CF-51 Pentium-M?
What internal is available for these models?
Internal wifi card wanted
Re: Internal wifi card wanted
I think you can use an Intel 4965AGN on this without connecting the 3rd antenna lead but someone else will need to confirm this!Pareto Optimal wrote:Is Internal 802.11N available for CF-51 Duo Core, CF-51 Pentium-M?
Jeff, where are you??
The MK1 and MK2 uses the mini pci card http://shop.ebay.com/i.html?_trkparms=6 ... p=15&_sc=1Pareto Optimal wrote:Is Internal 802.11N available for CF-51 Duo Core, CF-51 Pentium-M?
and the MK3 uses the Mini Pci-E card http://shop.ebay.com/i.html?_trkparms=6 ... p=15&_sc=1
Blair
Maybe I could just connect the G and the N?
Maybe I could add an antenna and route it to the palm rest?
I'm currently using an 11N PCMCIA card.
Last edited by Pareto Optimal on Wed Apr 20, 2011 4:29 pm, edited 1 time in total.
- Silver Trooper
While an N series card will work using only two antennas, you will need the third (correct) antenna to get the most out of the card, in other words, the transfer rate that comes with true MIMO products. In order for the multiple transfer paths to work (they are then combined to form one stream), the third antenna will be needed......I think.
