7mm SSD drive in HD caddy
Barney
#1 Post by Barney »
Will a 7mm drive be too thin for the caddy, or should I find a 9.5mm?
2 x CF-18, 1 x CF-19
Re: 7mm SSD drive in HD caddy
#2 Post by ADOR »
Worse case all you would have to do is thicken up the padding any if needed. Most of the newer ssd drives are all the thinner drives and have a thin piece of plastic around the edge to make up for the thickness.
Barney
#3 Post by Barney »
Thanks :spinny:
#4 Post by Rob »
The skinny spinning drives fit in just as good from what I've seen.
