CF-19 LCD REPLACEMENT
TOUGHNOVIS
#1 Post by TOUGHNOVIS »
I WAS WONDERING IF A LCD FROM A CF-18 PART NUMBER DFWV08A0076 WILL WORK IN A CF-19 MK1 ANY BODY :clapping:
Re: CF-19 LCD REPLACEMENT
#2 Post by Rob »
Is this a touch or a digitizer.
Please post the FULL MODEL NUMBERS!
TOUGHNOVIS
#3 Post by TOUGHNOVIS »
CF-19 MODEL NUMBER CF-19CHBAXBM AND THE PARTNUMBER IS ALL I HAD FOR THE LCD I DO NOT KNOW WHICH MODEL CF-18 IT IS FOR IT IS BRAND NEW PART NUMBER DFWV08A0076
#4 Post by Rob »
So this is a touchscreen model. That helps. Teo, where you at here? :P
TOUGHNOVIS
#5 Post by TOUGHNOVIS »
Rob wrote:So this is a touchscreen model. That helps. Teo, where you at here? :P
IT IS A TOUCHSCREEN I BOUGHT ON EBAY THANK YOU GUYS FOR YOUR TIME AND HELP I GUESE I DON'T ASK THE WRIGHT QUESTIONS OR GIVE THE WRIGHT ANSWERS
#6 Post by toughasnails »
Well yes and no :pat: . It can be done but it's a lot of work. I have a 19 with a 18 top and it does not work so I am looking for a whole top for mine. There is a post of mine talking about this.
Update
Here it is http://www.toughbooktalk.com/viewtopic.php?f=3&t=1048
TOUGHNOVIS
#7 Post by TOUGHNOVIS »
THE LCD IS Brand NEW .ARE YOU SAYING IT WILL NOT FIT IN THE CF-19 LID OR IS THE CABLE WRONG FOR THE LCD.
#8 Post by Rob »
You don't need to type in all caps.... Just sayin... :doh:
TOUGHNOVIS
#9 Post by TOUGHNOVIS »
Got it I am not good on key boarding.
#10 Post by Springfield »
member Teo has done a transplant CF-18 display onto a CF-19 body, but he is a Master hardware guy. Wait till he is able to give advice, not sure if it is something us mere mortals can do.
