Equipment Upgrade Needed. Details plus auction inside
Re: CF-74 MK 4 Auction end Sunday.
CF-74JCJBKAM.
Shawn offering to upgrade ram to 4 GB.
Bluetooth, 5725 WWAN, 5100 WLAN. Stylus...no tether. Working Touchscreen.
Thanks for looking,
Thanks for looking,
Re: Equipment upgrade needed! Details inside. $1 donation
My guess we will be running this until next Friday since we are just getting this started ??
Is this ending Sunday, October 27th or Sunday, November 3rd?
							CF-53    MX-Linux 21 Wildflower
I thought it was ending THIS Sunday.
Jeff can you please clarify?
I hate that there are 2 threads but I know we need it for NBR hot-linking.
The higher speed is officially turned up!
I have also confirmed that we are now getting 10M on the site.
Re: Equipment upgrade needed! Details inside. 74J auction.
Officially ends THIS Sunday at midnight Pacific as originally posted.
I will post up the 19 soon.
Power Supply OEM Panasonic added.
							THIS UNIT COMES WITH TWO DRIVES AS DESCRIBED. ONE "NEW" INTEL 335 SSD PLUS THE NEW CADDY WITH WORKING 80 GB RUNNING MINT 15. IOW THE CF-74 IS A STANDALONE UNIT AND THE SSD CAN BE PUT IN ANY OTHER COMPUTER THAT YOU OWN THAT ACCEPTS SATA.Todays add-on not previously mentioned is a Panasonic power supply.Includes in the factory sealed box the 3.5" adapter bracket, screws, wiring and power cables for a desktop for instance. Software is included for the SSD plus link to free Data Migration Software and Intel Solid-state Drive Toolbox.(It's in the box)
Take a few minutes...go to ebay and price it all separately. This is a tremendous value.
Ends Sunday 10/27/2013 @ midnight Pacific time.
Just a quick update here:
Getting a grasp on all the latest software is a VERY time consuming, tedious task. GOOD LORD!
Alas, I did get through and figure out what I'm doing with everything below. These are all tenative and I will go back to I know works if I have to for stability reasons:
Windows OLD: Server 2003 Standard SP2
Windows NEW: Server 2008 R2 Standard
Apache OLD: 2.2.11
Apache NEW: 2.2.25 (Might do Apache 2.4.6 but only if I can handle it)
PHP OLD: 5.2.13
PHP NEW: 5.5.5 (32)
PHPbb Board OLD: 3.0.8
PHPbb board NEW: 3.0.12 (For SURE I'll update this)
MySQL OLD: 5.0.67
MySQL NEW: 5.6.14 (But only if I can get the database working on the new system)
Cerberus FTP - SAME - Not Free Anymore
PPTG Network Monitor OLD: 7.1.3.3376
PPTG Network Monitor NEW: 13.4.6.3305 (Only has support for 10 sensors so I might use the old one instead)
Robocopy - SAME
Temperature@lert - SAME - 4.0.8
Apache OLD: 2.2.11
PHP OLD: 5.2.13
PHP NEW: 5.5.5 (32)
MySQL OLD: 5.0.67
Robocopy - SAME
CF-74 bid is Ken @$450. Do we hear $500.
