What Models are you still playing with?
monocle
Re: What Models are you still playing with?
#21 Post by monocle »
I have a FZ-G1 (Mk4) Upgraded with 1tb sata ssd, killer AX1675x, ikey rugged backlit keyboard, and an EM7455 using ATT. I also have an MK1 that works. That one has a 128gb ssd and 8gigs of ram with an ethernet module.
thewanderlustking
#22 Post by thewanderlustking »
UNCNDL1 wrote: Sat Jun 25, 2022 8:04 am
thewanderlustking wrote: Sun Apr 17, 2022 10:52 am
UNCNDL1 wrote: Wed Mar 09, 2022 1:51 am Still using Linux exclusively on the 52. I just love the red led’s highlighting the kb.
Is this a custom mod? I couldn't find any pictures of it in the dark. I want to know more, this sounds super cool. Would love to see a picture!
Here's a picture of the LED's, they are red, one in each corner at top of screen. The brightness is controlled by holding down Fn key and the up/down arrows. This allows the keyboard to be lit up from above (so to speak) Model # is:
CF-52GUNBRAM
Thats super cool! And it is YOUR fault I went to the darkside.... When I went looking for pictures of that, I found the Getac B300. And ended up with one as you can see lol.
CF-3110778CM, CF-19ADUU51M
DaveW67
#23 Post by DaveW67 »
I have a CF-28 I built a few years back. It’s running Windows XP. I don’t use it very much but it was a fun build. I have a CF-30 that I used in my field work. have 3 CF-53’s (a MK2 and 2 MK5’s). My son is using the MK2 for college, my other son has a MK5 and I have the other MK5. A couple weeks ago I picked up a CF-31 MK5 and that will be my new field unit.
KarlKlammer2
#24 Post by KarlKlammer2 »
my oldest is a cf19mk3 from 2008. has been used till january 2023, 15 years ... then replaced with a t420 (for half a year, feels cheaply made) and then with a cf54mk2
cf19mk3(4gb,512gb,wwan)@Ubuntu
cf19mk6(16gb,512gb,wwan,gps)@OpenBSD (lost on train)
tabactive2(4gb,256gb)@Android
t420(16gb,256gb)@OpenBSD
cf54mk2(16gb,512gb,fhd)@Windows+dock+EliteDisplay24"+MxKeysS+MxAnywhere2
interestingfellow
#25 Post by interestingfellow »
I still have 2 FZG1 MK1's for win7 and I just picked up a F110 G3 that I put Mint on.
Hey, y'all!
thewanderlustking
#26 Post by thewanderlustking »
I may have a Toughbook problem...
My current models sitting on the side table getting played with are a CF-20 and a CF-33. The CF-20 is essentially perfect and complete, just a CF-20 lol. The CF-33 is the tablet without the keyboard that I just picked up and likely has a bad touchscreen.
I have a MK5 CF-19 under the side table, it is complete and working. Gets used for tuning. It is one of the ones with the camera module, so its limited to 8 GB memory unfortunately, I don't really have any reason to keep it, other than it has a working legit W7 on it... I have another CF-19 MK6 (I believe) sitting on my workbench. It is a friends though.
I also have two CF-M34 under the coffee table. They both work, but the complete one I believe lost its PATA HD. It could be the motherboard though... I have the parts to swap the drive out and put in an SD card, the goal being a raspberry pi machine.
My CF-31 is on my back desk. I think Windows 7 broke on it, and my attempts to Hackintosh it fell short.
I still have that Getac B300 above, unfortunately its battery, or the chargeing circuit, took a poo. I really like it but am hesitant to spend good money on a battery, to find out it is the charging circuit. I may try jump-starting the battery.
This isn't including whatever parts laptops I might still have....
liteace
#27 Post by liteace »
Ive 2 CF-19s, both with 1Tb samsung SSD's in, 1 Mk4, Ive had for about 14 years, the other Mk5, a CF-20 Mk1 with a 2Tb Samsung SSD + docking station + about 10 batteries, On the way to me is a CF54 Mk3 that will have SSD upgrade to a 4Tb or 2 x 2 Tb's and some extra memory
