CF-19 LCD and touchscreen
LarsL
Re: CF-19 LCD and touchscreen
#21 Post by LarsL »
Shawn wrote:Here is the exact LCD panel for $150.
http://www.aliexpress.com/store/product ... 18355.html
For what I can see, the panel listed on Alienexpress, but if this is a BS-site and of you get screwed I don’t know. For what I can see they don’t use PayPal so one wouldn’t get any delivery insurance.
LarsL
#22 Post by LarsL »
Furthermore, the second number doesn’t match
AG101E13900000Y7A31F
If you search the first number, you will be able to find LCD on Ebay as well. However those are not compatible.
Confusing!
Edit, all numbers in text format.
GCX514AKN-E
T01F32645043Y11 G
#23 Post by Shawn »
I have purchased via Aliexpress in the past. I used a credit card to pay, so I was protected through the credit card company.
LarsL
#24 Post by LarsL »
Shawn wrote:I have purchased via Aliexpress in the past. I used a credit card to pay, so I was protected through the credit card company.
That could be an alternative Shawn.
The thing is, the other numbers doesen´t match and if you search on Ebay, you find similar looking LCD´s with the same number, but with a incomptible size.
#25 Post by Shawn »
I did not see any on ebay.
It comes up zero matches, then it show "SIMILAR" items.
Please post an ebay link or two
LarsL
#26 Post by LarsL »
#27 Post by Shawn »
I took a screen grab.
The listings are "RELATED TO" GCX514AKN-E They are not GCX514AKN-E. That is why they are the wrong size.
LarsL
#28 Post by LarsL »
Opppps my bad :pat:
Thanks Shawn!
#29 Post by teo »
You can still use the complete LCD panel from MK3 or MK4. Just disconnect the sensor. Its useless anyway as User32 said. Also it has better screen than those from MK5 or MK6. Use the existing cable of your unit though.
User32
#30 Post by User32 »
teo wrote:You can still use the complete LCD panel from MK3 or MK4. Just disconnect the sensor. Its useless anyway as User32 said. Also it has better screen than those from MK5 or MK6. Use the existing cable of your unit though.
I remember Alecgold using a Mk5 upper to fix his Mk6 with a busted screen.
