Newbie Needs Help With XP Install (new project)
Re: Newbie Needs Help With XP Install (new project)
#21 Post by SHEEPMAN! »
The pictures are nice but WAAAAAY too big.
The size you want is where it can be read/seen on a 13.5 screen without side scrolling. Can you please edit your post and re-size. 800x600 maximum....
Jeff......Society of folks that don't own a desktop....:D
AutoFreak
#22 Post by AutoFreak »
UPDATE - I thought that I would rebuild the machine as I didn't want to lose any bits while it sat around my house and thought that I would try the installation one more time. It successfully formatted the disc and I am currently on 39% of the installation of the recovery disc for XP. Don't ask me how, but fingers crossed! !!!
#23 Post by SHEEPMAN! »
Do you have a sata to ide converter in the drive?
Most phones have a setting somewhere.
What operating system are you using? Maybe I can suggest a resizer.
You're not typing these nice posts on the phone are you? :pat:
AutoFreak
#24 Post by AutoFreak »
I got to disc 2, and then got a write error :doh: so am trying again now.
Its juat the standard HDD (non SATA) and installing Windows XP as I asssume its what is on the system recovery discs ?
I was writing the last few posts on my phone lol but am now on the big boys computer now :P
AutoFreak
#25 Post by AutoFreak »
I got her working guys !!!!!!!!
AutoFreak
#26 Post by AutoFreak »
Sooooooooo next question............ How do i get the touch screen to work :)
#27 Post by SHEEPMAN! »
Sometimes it takes two boots to get things going.
Touchscreen:
Does it appear in bios? This would mean the machine sees the TS and the Touch Panel is de-laminated.
Send me a picture of your device manager with mouse expanded.
In C: do you have a \util directory?
Don't just throw drivers at it....it's probably hardware (the touch panel).
AutoFreak
#28 Post by AutoFreak »
I just checked and yes it appears as ACTIVE in bios. If I search UTIL in C: it shows a Utility Manager and a UTIL file ? I will post a picture now but I am having problems uploading them and it will appear MASSIVE so you might have to click on the "show image" to view it correctly
AutoFreak
#29 Post by AutoFreak »
Hopefully this works
#30 Post by SHEEPMAN! »
http://pc-dl.panasonic.co.jp/dl/docs/00 ... &trn_org=2
This is the one and only touchpad/touchscreen driver. If you have /util you have this already.
I usually check touchscreens with a non-pae Linux stick or in your case a CD/ROM. No USB in boot order.
Your picture is correct. It's huge again, does your big boys computer run W7?
Do a search for image-resizer. Install. Copy from phone to big boy. If you find the right resizer it should show up in right click menu.
Watch for PM.http://microsoft-powertoys-image-resize ... tonic.com/
