What do you guys use your Toughbooks for?
Re: What do you guys use your Toughbooks for?
#21 Post by Springfield »
Some get used for target practice . . .
[This is my own picture from a Saturday "shoot" with friends a few years ago. Posted it on a shooting forum and since then I've seen it pop up several other places on the Net.]
safn1949
#22 Post by safn1949 »
CF-27?
#23 Post by SHEEPMAN! »
:pat: What is that? A shotgun? 300 yard open sights?
#24 Post by Springfield »
Had a stack of older CF-27s I got for a couple of bux each. Took the roughest ones for range practice. Bullet hole at lower right edge of display is probably 7.62mm from AK-47, and most the rest of the visible holes were 22 rifle, then a shotgun at 10 yards actually ripped off the keyboard and top of the chassis. I pushed the shattered parts back into place for the photo.
#25 Post by kode-niner »
Springfield wrote:Had a stack of older CF-27s I got for a couple of bux each. Took the roughest ones for range practice. Bullet hole at lower right edge of display is probably 7.62mm from AK-47, and most the rest of the visible holes were 22 rifle, then a shotgun at 10 yards actually ripped off the keyboard and top of the chassis. I pushed the shattered parts back into place for the photo.
Did the 7.62 penetrate?
#26 Post by Springfield »
kode-niner wrote:Did the 7.62 penetrate?
Yep believe it went clean through the edge of the display. I'll try to find another pic of the top side to verify.
#27 Post by ADOR »
If it was a lot of that older surplus ammo it will go though a lot they sometimes have a steel core making it a minor AP round. The old bolt action 7.62 x 54R rifle I have the first time I shot it went straight through the steel back stop we have. You could see a perfect hole in the plate and around the edge of the hole it still had the jacket of the bullet, lol. Oh yea, the plate was 1/2" think. I have seen some where it will go though 3/4" thick but haven't tried it personally.
#28 Post by Springfield »
27 after a few shots with the AK.
27 after getting all shot up. Dirt streaks are from shotgun at close range. Note the back of the display shows a few 30cal / 7.62 sized holes. I'd think 22 rifle would also penetrate but if you look closely there are a few smaller bumps that don't seem to go through.
#29 Post by Shawn »
So who will do the same test with a Dull, HP or Mac?
#30 Post by toughasnails »
Well a few years ago Rob posted a few video's of him killing a few Dells, HP but it did take a few try's to kill a Toughbook if I remember right :lauging:
