OBD2 software on laptops.
Re: OBD2 software on laptops.
#11 Post by ADOR »
Have you used this on just the one pc? or have you tried it on another one?
Mxx20
#12 Post by Mxx20 »
I havent tried the obd2 ones but i know on the medium and heavy duty trucks the drivers for the com adapters are finicy at times. And some software changes the drivers to an older one.. Had a nexiq usb link blank out during a firmware update today(someone tried and bricked it but yeah...)
Bill_TN
#13 Post by Bill_TN »
I have a nexiq at the shop. Love that little toy. Ador, I've tried it on a cf-19 and a Dell 630 so far. The 19 is a full blown active vista install and the Dell is an up to date valid 7 install.
Bill_TN
#14 Post by Bill_TN »
Also thinking about firing up my cf-30G3SZZAM. Under either Vista or XP and then flip to 7 and adjust as needed if needed. So looks like going to have 3 different units trying to get this crap together.
LOL. Actually had a guy try to tell me that I can't set up a hdd to run all programs on one machine, and then pull the hdd and stick it into another unit. With bolth being exactly the same, that is easy. As long as they are close to one another it can still be done. Aggravates me when people try to tell me can't be done when I've done it time and again.
#15 Post by ADOR »
I have 7 pro on my personal CF-30 so any of those it should work fine on. In device manager can you see it plugged in and when you unplug it?
Bill_TN
#16 Post by Bill_TN »
From whet I recall yes. But would have to boot a unit to be positive. Headed to bed tonight. I'll try to remember to check tomorrow. But yea come to think about it yea the Vista at least does. It even finds the drivers for me when I plug it in. I think the issue is in the vehicle interface itself.
#17 Post by ADOR »
If I remember right check your cigar lighter fuse as it's connected to your OBD 2 port. If that fuse is blown your port won't work.
Bill_TN
#18 Post by Bill_TN »
The nexiq at the shop reads them both fine.
Bill_TN
#19 Post by Bill_TN »
Just got one of these. Macbook Air A1237 13.3" Plan to windohs it and try the software there next. LOL.
#20 Post by ADOR »
Windows on a Mac. Sounds like my kind of mac, lol. I haven't got to get my hands on one to feel the weight in person. How do you like the feel of the air?
