How do I put a shoulder strap on my new CF-53?
Re: How do I put a shoulder strap on my new CF-53?
#11 Post by Shawn »
#12 Post by Shawn »
ADOR wrote:Haven't I seen some toughbook straps in the past that were cloth only and would go right into that?
Camera straps are all cloth/nylon and would fit.
#13 Post by ADOR »
I had one before that was long and thin, had small padded area that said toughbook. Not sure what toughbook I had it came with.
#14 Post by SHEEPMAN! »
Will the clips fit through the holes Shawn mentioned? (Rugged Depot Picture above)
The split ring idea is better that mine.
And camera straps are a good idea. Also binocular straps.
http://www.amazon.com/Camera-Strap-Conn ... B003G5WKDG
For the split ring put a circle of leather with a slot in it over the ring as an anti-rattle device. Then clip on your strap.
#15 Post by Rob »
Shawn, I thought about using those two tether loop hole thingy's with a key ring but thought it wouldn't be tough enough although I guess it wouldn't hurt to try it?
I'll letcha know later! :)
#16 Post by Shawn »
Another idea is use the D rings from a 27 handle, and Dremel the needed grooves in the CF53 handle..
#17 Post by Rob »
Shawn wrote:Rugged depot sells these...
http://www.ruggeddepot.com/intermec-pb2 ... der-strap/
I already have one :)
#18 Post by SHEEPMAN! »
So....who has a spare set of handle pieces (brackets?) and a set of 27 Dees?
I'm guessing the D's are not welded. 53 on top, 27 on bottom. (In the picture)
#19 Post by teo »
As suggested above. A small round file can do the job. As seen on CF-27 handle and then use the "0" ring.
#20 Post by Rob »
It's funny because I had a CF-27 handle which I felt I'd NEVER need seeing as it sat in my drawer for 8 years.... I sold it to someone here..... Don't remember who....
Wanna sell me a CF-27 handle???? :P
EDIT: Calling Shawn.... I sold it to you big guy! :P :sucks:
