linux gps map software
Re: linux gps map software
The map link is the same as I used to download maps previously. I followed all your instructions, except that I renamed the downloaded map as 'osm_ca.bin' and used leafpad as the editor for the navit.xml file, but see no change in Navit...blank window with a blue circle. Strange.
When you open navit and go to setup -> maps, does your binfile show up there with the proper path?
When I open Navit and go to settings->maps, the only thing showing is 'Route', 'Route Graph', 'Navigation' and 'Tracking' options, with 'Route' being the one enabled (check marked). I double checked your previous instructions and all is as it should be.
Post your navit.xml file as an attachment and I'll take a look.
Okay, here it is.
- navit.xml
- (290.58 KiB) Downloaded 944 times
You have a sample mapset enabled right above yours and it needs to be disabled. Your map should be the only one enabled with
Set the sample mapset to "no" and you should be good to go.
<mapset enabled ="yes"> Daily drives a CF-31
Ah, missed that one. Made the change and I have a map with the circle on my location. Thank you.
How do I use the other maps I downloaded? How high of resolution (how close to street view) will the maps go? I have downloaded a bunch of maps of Western Canada and the West Coast of the US at increasing levels of zoom. Do I need them and if I do, how do I enable them. All the maps are already in the navit/maps folder with names like osm_bbox_-116.3,50.2,-109.3,53.4.bin, etc.
Right now you're running navit in its most basic configuration. There are plenty of fun tweaks that can be added if you have the patience.
You can have multiple maps but only one mapset. It would look something like this:If the maps exist and are enabled as above, you go into Settings -> Maps to check/uncheck the ones you need to use.
For the zoom levels from maps that you grabbed from OpenStreetMap, they are already sufficiently detailed. There's a keyboard shortcut for zooming but I can't find it or it's not working anymore. I think it was an F-key. Otherwise you need a mousewheel to zoom which ain't so great with our TB's. However there are plenty of On Screen Display (OSD) tweaks you can do to help:
Look for these two lines and enable them (change "no" to "yes") to get two buttons on screen where you can tap to zoom.
Where it gets cool is you can copy a bunch of osd tweaks from here for some pretty cool layouts. Sometimes I use them for insipiration by picking and choosing individual osd lines from some of their layouts instead of using their entire kits.
http://wiki.navit-project.org/index.php/OSD_Layouts
<mapset enabled="yes">
<map type="binfile" enabled="yes" data="/usr/share/navit/maps/osm.bin"/>
<map type="binfile" enabled="yes" data="/usr/share/navit/maps/osm2.bin"/>
<map type="binfile" enabled="yes" data="/usr/share/navit/maps/osm3.bin"/>
</mapset>For the zoom levels from maps that you grabbed from OpenStreetMap, they are already sufficiently detailed. There's a keyboard shortcut for zooming but I can't find it or it's not working anymore. I think it was an F-key. Otherwise you need a mousewheel to zoom which ain't so great with our TB's. However there are plenty of On Screen Display (OSD) tweaks you can do to help:
<osd enabled="no" type="button" x="-96" y="-96" command="zoom_in()" src="zoom_in.png"/>
<osd enabled="no" type="button" x="0" y="-96" command="zoom_out()" src="zoom_out.png"/>Where it gets cool is you can copy a bunch of osd tweaks from here for some pretty cool layouts. Sometimes I use them for insipiration by picking and choosing individual osd lines from some of their layouts instead of using their entire kits.
Here, I edited your navit.xml file and added a few osd tweaks to get you started. I put them under a section I tagged for you with
<!-- BEGIN custom osd items -->
If you want to have fun with osd, it should be safe for you to play around with those at will.
- navit.xml
- (291.76 KiB) Downloaded 907 times
Thanks for the info and the doctored navit.xml. I will check it out. I appreciate the help.
