Windows 7 Pro CF-U1
Re: Windows 7 Pro CF-U1
OEM serial wants OEM version of iso. I guess MS doesn't let you download the OEM version. (ASSuME)
I have a Dell OEM Win7 DVD that I use for OEM COA installs.
You still will have to call Microsquash for activation.
If you want the drivers installed with the OS reload yes, if not you will have to get any OEM restore disk that will have just the basic windows install and then you can install the drivers manually.rrtek wrote:So I have no choice, I have to get the panasonic DVD.
MS allow sharingrrtek wrote: Yes, It came with Windows XP from factory. Doesn't anybody know where I could get the iso? I don't think is legally wrong to share the DVD as long as I use my serial number.
If you use another "brands" iso it will say DELL, HP or what ever it was you used. But that can be changed with software easy.
http://www.ebay.com/itm/New-Sealed-Dell ... 2ee0313d4b
Good example and the cheapest price I found. 15 bucks shipped, but that is in the USA.
ADOR, I was thinking of another bay.ADOR wrote:http://www.ebay.com/itm/New-Sealed-Dell ... 2ee0313d4b
Regards.
