CF-28 Blank screen on Boot
Post all questions and information about the CF-28 in here.
gazucha
Re: CF-28 Blank screen on Boot
#11 Post by gazucha »
ADOR wrote:Did you check to see if that DVD drive was set to master as Springfield asked earlier? Just trying to narrow it down.
Didn't check that, but did try booting with the DVD Rom removed, with no joy.
Will try again now though, as I have a different OS installed.
Is the 'Master select' when you solder across the 2 pins on the drive adaptor?
...edit... Doesn't Boot without DVD Rom...
#12 Post by Rob »
If its a 160gb Samsung its simply not compatible!
Try a different drive and post your results! I had this problem with cf-29's myself and I NEVER found a solution other than to use a western digital drive!
gazucha
#13 Post by gazucha »
Rob wrote:If its a 160gb Samsung its simply not compatible!
It currently has a 40Gb Hitachi installed with Ubuntu 9.10, and it still stalls on Boot.
I must say, it has crossed my mind as to whether or not I need a sparkling new Hard Disk in order to satisfy this machine!
#14 Post by Shawn »
Have you tried the original 30gb drive? What is the bios boot order? What are you formatting the drives as fat 16, fat 32. just throwing ideas....Photos of the hdd caddy and cable...maybe defective or cheap Chinese knockoff??? Wrong size caddy? I dunno much about that other than I read cf28's use different size caddies.
Load DOS on the hdd and see if it boots....
#15 Post by ADOR »
Is the jumpers on the hard drive correct?
gazucha
#16 Post by gazucha »
Shawn wrote:Have you tried the original 30gb drive? What is the bios boot order? What are you formatting the drives as fat 16, fat 32. just throwing ideas....Photos of the hdd caddy and cable...maybe defective or cheap Chinese knockoff??? Wrong size caddy? I dunno much about that other than I read cf28's use different size caddies.
Yes, tried without success the original 30Gb Hd (or at least the one which came with the CF-28. A Toshiba MK3017GAP).
Boot order is currently;
CD Rom
Hard Disk
Floppy
Have been formatting in either Ext2, Ext4, or NTFS depending on system and partition type.
Caddy was working fine for first 2 years and the Bios always reads the Hard Disk I.D. clearly.
How do I load DOS and what should I load?
Thanks.
gazucha
#17 Post by gazucha »
ADOR wrote:Is the jumpers on the hard drive correct?
Hard Drive without Jumpers as this normally sets to Master.
gazucha
#18 Post by gazucha »
After months of searching, no-one seems to know what the problem is, so am gonna sell the CF28 as is!
Thanks for all your help.
gazucha
#19 Post by gazucha »
Here's an update...
was trying to load Ubuntu 8.04 this afternoon and this happened to the screen... (see attachments)
Could this be the culprit to the OS failure?
What might cause this? Video card?
Anyone seen this before?
I did have the Laptop disassembled last week in the search for the root problem. Did I miss-connect something?
Returned to normal after reboot
#20 Post by toughasnails »
I have never ever seen that happen before on any laptop :eek:
Return to “CF-28 Talk (Discontinued Model)”
